If you use your propane furnace, you won't need tank heaters. There are heat ducts from the furnace to the tanks. We once had a 25 mph wind and 19 F overnight. The compartments with the water pump and filter, and with the tank drains, were over 50 F. I never turned the tank heaters on.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
