Originally Posted by bob dirt
I had to remove the limit screws so I could adjust it to see the horizon. I just rotate it down when backing up to my trailer. I like to use it as a rear view mirror...not just looking at what's right behind me.
I ran a video feed from my Jensen in dash system back to my trailer hitch and then a video cable and feed to the back of the trailer where I have a camera mounted so I can see when backing the motorcycle trailer.
I also added a camera on the rear bumper. I hook it into the video feed I ran from the Jensen in dash system and use it when I am backing up to the trailer.
I have the main camera on the back of the motorhome aimed so that I can see from about 3' to about 25' behind the motorhome and use it as a rear view mirror as well as checking to see if a care is riding too close.
The Jensen system in my motorhome already had the back up wire feed hooked up so the only the video feed had to be run front to back. I picked up the reverse feed for the bumper mounted camera from the trailer hitch wiring harness.
The set-up gives me a lot of flexibility and quite inexpensive if your a do-it-yourselfer.
