Old 10-18-2018, 10:15 PM   #1
Air Ride PSI?
Just got the trailer and never had air rides before. When I checked them, there was no air in them at all. I put 60psi in one and then the other wouldn't take any air at all. Fortunately I had a Schrader valve core laying around and when I changed out the core it took air so I put 60 psi in that side as well. Hopefully, tomorrow when I check them they both will still have 60 psi in them.
The question is, what is a good pressure for these to start with? I guess everyone is a little different but I thought it would be good to hit the average to start.
Thanks!
2014 Sunseeker 3010DS on Ford Econoline E450 Chassis
Newly Retired!!!!
Atlanta Panther is offline   Reply With Quote
Old 10-19-2018, 05:45 AM   #2
Dcbenny's Avatar
From what I have read most run between 55 and 65 I run mine at 60 I do check mine monthly or when leaving on a trip and almost eveytime I have to add a few pounds
Don & Liz B.
Pink Retired Greyhound
2016 GTS 2800QSF
Dcbenny is offline   Reply With Quote
Old 10-19-2018, 07:13 AM   #3
Shredder's Avatar
I have tried 60 PSI helped a bit but with a full load wife kids water dog and the kitchen sink I run around the 75 to 80 range. It all depends on your unit the load and the type of ride you are looking for.
Bob
2013 Forest River Sunseeker 3010DS
Shredder is offline   Reply With Quote
Old 10-19-2018, 07:54 AM   #4
I was running 50 but found 70 to handle the hard bumps better.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 10-19-2018, 08:34 AM   #5
Duckogram's Avatar
I started at 50 and ended up at 70. The load dictated the change. Rides great and helps reduce body roll. The airbags are like bicycle tires in that they require airing up frequently. So frequently that I am installing an onboard compressor with dual switch and gauges up front so I can just push the button to adjust them.
Here is a link to the February discussion:
http://www.forestriverforums.com/for...ml#post1716255
ILB ( | )
Old 10-19-2018, 09:28 AM   #6
Dcbenny's Avatar
I am going to adjust mine to 70 psi for my trip in November to see if there is any difference in handling also getting MH weighed next week and adjust tire pressure as needed, right now set at sticker on door
Don & Liz B.
2016 GTS 2800QSF
Old 10-21-2018, 11:23 PM   #7
Garrette's Avatar
I think the airbag pressure is a minimum of 10lbs and maximum of 90 lbs.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 10-22-2018, 05:00 PM   #8
Minimum is 20 lbs.
Kim
bayoubelle is offline   Reply With Quote
Old 10-22-2018, 06:01 PM   #9
Usually Confused Member
emm-dee's Avatar
I did a test while driving a three hour trip. All on non-interstate roads. I have the remote compressor so was able to change the pressure while driving. I varied the pressure from 25 to 95 psi. Results....I didn’t see any difference.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
