Old 03-24-2016, 08:25 PM   #1
Air ride question
We have air ride bags on the back area of our Sunseeker 3170. I was wondering what kind of portable inflater do any of you use. It's too expensive to install remote ones and we don't want to be stuck having to go to a gas station. Also, we just had automatic levelers installed. Is there any reason we'd need to adjust the air rises when using the levelers? Thanks for any help. This is new to us.
MzZorro is offline   Reply With Quote
Old 03-24-2016, 08:35 PM   #2
Ford Idaho's Avatar
Some thing like this would be more than enough.
12Volt 150 PSI Compact Air Compressor
Old 03-24-2016, 08:40 PM   #3
Kenny kustom's Avatar
Air ride question
As long as you don't severely change you load, it's kind of a " set and forget thing.
( assuming no leaks either) ..
Check it every once in a while.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 03-25-2016, 03:25 PM   #4
Hoglou's Avatar
pump it up
A small , very small 120 or 12v pump will do the air bags, but not the tires. It does not take much to fill the bags. Stay below 100 psi...
I actually carry both a small cheap ($20) one for the bags, and an expensive vair 450p for the tires.
Hoglou the DH (1231 and done!)
BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 03-25-2016, 08:47 PM   #5
I have a Viair and really like it. Would get the RV model next time but it is more expensive.
2014 Sunseeker 2860DS
gmacklem is offline   Reply With Quote
Old 03-26-2016, 11:54 AM   #6
JimOneil43's Avatar
What is the model # of the Viair Compressor that you use? What is the difference in the one you have and the "RV" model?
Retired and loving it...Can't wait to get back on the road!
2017 Forester 3051S ("Farley")
Born April 18, 2016
Toad: 2014 Honda CR-V AWD
GO DUCKS !!
Jim & Diana (and 3 cats)
JimOneil43 is offline   Reply With Quote
Old 03-26-2016, 02:21 PM   #7
I have the 300P. The difference between mine and the RV model is mine must be shut off when not inflating. That is, you can't let it run while you move from one tire to the next, it will continue pumping and blow the hose. Most tankless compressors work this way it seems. But the RV model actually has a shutoff. So you don't have to have the compressor right with you while you go around the RV.
Old 03-27-2016, 08:11 PM   #8
Thanks for all the great advice. We don't have a 12 volt outlet in or near the bay's. Any cordless options?
Old 03-27-2016, 08:26 PM   #9
RedLdr1's Avatar
Look for a "jump start box" that has a built in air compressor. You can find them at Home Depot, Lowes, Sears, Walmart, or some automotive supply stores. I have one with a built in flashlight and air compressor that was about $40 on sale after Christmas.
Wayne and Christine
2021 R-Pod RP-192 with OEM Solar
2020 Ford F-150 Lariat SuperCrew FX4, 3.5L EcoBoost, Max Tow Package with 1572# Payload
RedLdr1 is offline   Reply With Quote
Old 03-27-2016, 08:34 PM   #10
Ford Idaho's Avatar
Bet this would reach far enough.
25' 12-Volt Extension Cord - Prime Products 08-0917 - Electrical Cords - Camping World
Amazon might have it for less.
Old 03-27-2016, 11:19 PM   #11
RETIRED AND LOVING IT
n-e-d's Avatar
I have the Air Lift Load system for my rear bags. About the same price as the expensive Vair. Gauge up front on dash with push button adjustment. Always know pressure in bags. Have a Porter Cable 1.5 electric compressor in rear storage plugged into Dyson outlet and 50' of hose for sunseeker and biketires. Just kick on generator if not connected to 110 power.
Mary and Me 😷😷 Stay Safe
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Diesel Cargo Van HR DRW EXT "Red Roamer"
"I am in the prime of my decrepitude"
n-e-d is offline   Reply With Quote
Old 03-28-2016, 04:56 AM   #12
I use a bicycle air pump for the air bags. The bags are small so a lot of volume is not required.
Lee and Anne
2016 F250 2WD CC SB XLT 6.2 3,295 lb payload cap.
2014 Salem Hemisphere 282RK 8k lbs loaded, Equal-i-zer WDH, TST 507 TPMS
2021: 35 nights already booked so far
Teamfour is offline   Reply With Quote
Old 03-28-2016, 05:38 AM   #13
We have a Campbell Hausfeld 12V inflater that is used for "Bike's/Air shocks/ Bag's/ Truck and RV tires"! Even used it to pump up a Class A Bus tire,that had NO spare,took a while but "Did the Job"! Ours is 20+ years old and still going! Youroo!! They still can be purchased for under 50$
Old 03-28-2016, 06:30 AM   #14
Sagecoachdriver's Avatar
2X
I tried using a 12v pump, but a HF bike pump was a simple solution. 5-10 pumps and done. Took more time to unpack the 12v pump and setup than to use this pump.
HF for $10.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 03-28-2016, 07:33 AM   #15
trdutch's Avatar
I have one of these also.I got it at Tractor Supply.
Mine is rechargeable battery so easy to use it has a spot light built in so it's a lightweight handy tool for the road
I never saw a Hearse towing a Trailer
'71 Dads VW camper pop up Van
'78.....tents
'93 Coleman pop ups (I'm Dad)
'04 Fleetwood Jamboree 26q
'14 Sunseeker 2860DS
trdutch is offline   Reply With Quote
Old 03-28-2016, 08:56 AM   #16
Originally Posted by Sagecoachdriver View Post
2X
HF for $10.
X3
GJones is offline   Reply With Quote
Old 03-28-2016, 03:24 PM   #17
Hoglou's Avatar
If you do go 12v you should pull from the battery. The viair will do the 85 psi tires....
Old 04-02-2016, 08:01 AM   #18
I have a pancake compressor from HF and a 25 foot coil hose with quick connects plus truck tire chuck with gauge. Less than $75 for the pile. It sits in the compartment and can reach outside outlet, hose reaches every where without removing from compartment. Also handy around home.
Nomadbull is offline   Reply With Quote
Old 04-02-2016, 10:38 PM   #19
https://www.amazon.com/Viair-40047-A...ire+compressor
bdifonzo is offline   Reply With Quote
Old 04-02-2016, 11:15 PM   #20
Originally Posted by bdifonzo View Post
X2..
Wife just bought me this for my birthday!
2016 Sabre 36QBOK
