Old 03-31-2023, 04:31 PM   #1
zoesdad's Avatar
Alarm
I have an alarm on my 2017 Forester that keeps going off. Propane tank is full, all other tanks are empty, fridge is working and I changed the battery in the smoke alarm. No luck. Any idea on how to reset or turn off the alarm, it sounds like it is coming from the e fridge area.
zoesdad is offline   Reply With Quote
Old 03-31-2023, 04:52 PM   #2
Three gases sensed
Three gases are sensed in an RV:
Smoke:The smoke alarm is always mounted on the ceiling since smoke rises.
Propane: The propane detector is always mounted at floor level since propane is heavier than air.
Carbon Monoxide (CO): Usually the CO detector is combined into one of the two detectors above.
The smoke (and maybe CO) detector usually uses a battery, often the 9-volt units with two snaps on the top.
The propane detector draws a lot of current and runs off the house battery. There are three reasons why it could beep:
  1. It's sensing propane (or dog farts or something else)
  2. The house battery is low (very common)
  3. Its internal timer has expired and it wants you to replace it.
Usually each of these has a different beep pattern or LED-flash pattern. If you don't have the manual in all the stuff that came with the motorhome, you could lift it off its mount and read the instructions that are often printed on the back side.
Larry
Larry-NC is online now   Reply With Quote
Old 03-31-2023, 04:55 PM   #3
Certified Curmudgeon
Duckogram's Avatar
The fridge, if set on gas, and the flame does not light or goes out, will alarm depending on the model. Norcold?
Happy Trails and Remember the Pequod.
Old 03-31-2023, 04:57 PM   #4
zoesdad's Avatar
It’s a single beep Every minute or so. I thought it could be the propane since I ran the tank empty but I just filled it up. Battery is showing 13v. Might have to try and locate the propane monitor. Thanks!
Old 03-31-2023, 05:13 PM   #5
zoesdad's Avatar
The fridge is set to auto and running on power. I did have to reset it when I ran out of propane. Not sure if the brand but I believe it has electric ignition. Will look that up too. Thanks
Old 03-31-2023, 05:31 PM   #6
It could also be that the propane detector needs to be replaced. Yours is getting to the end of its useful life and a single beep every minute or so usually means that it's failing.
They are usually near the floor near the refrigerator.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 03-31-2023, 05:40 PM   #7
zoesdad's Avatar
It’s a Dometic
Old 03-31-2023, 07:12 PM   #8
Flybob's Avatar
The CO/Propane detector has a 5 yr life span from the mfg date. After that it will beep to indicate it is out of date. Pull it and check the date printed on the back. Be careful not to short the wires or lose them in the wall.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 03-31-2023, 07:52 PM   #9
Duckogram's Avatar
The fridge will only alarm once. I’d go with the flammable gas detector.
Old 03-31-2023, 10:03 PM   #10
Retired Old Fart
dward51's Avatar
Most likely the CO/Propane detector. In a 2017 model it should be right at it's end of life. Apparently there is an internal clock that when power is first applied, starts to count down. When it hits so many hours, it's time to replace it. You cannot reset that alarm (made to be that way for safety). They are about $65'ish on Amazon for the more common models.
Just the 2 of us in a...
"Currently between trailers"
Sold the 246RKS in 2023
dward51 is offline   Reply With Quote
Old 04-03-2023, 09:23 AM   #11
zoesdad's Avatar
Any one know where the propane alarm is located on a 2861ds? I can not find it. Only place I have not looked is the sink cabinet that is not accessible when the slide is closed
Old 04-03-2023, 10:50 AM   #12
That is where it is in my 2017 2861DS.
2017 Forester 2861DS
towing 2015 Jeep Rubicon
fobagbob is offline   Reply With Quote
Old 04-03-2023, 11:08 AM   #13
Duckogram's Avatar
Beep Beep
This is what you are looking for…
