Old 01-24-2015, 01:35 PM   #1
hockeytownmom's Avatar
Another Big Foot Question
Automatic or Manual. That is the question. Pros/cons?
Kristina
hockeytownmom is offline   Reply With Quote
Old 01-24-2015, 02:16 PM   #2
Mddle of the Rd Extremist
MeepMeep's Avatar
Automatic - more towing capacity and ease of operation. When I was younger, rowing thru the gears was much fun, now not so much....today's automatics are so good, I really don't know why anyone would choose a manual, but to each his own
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 01-24-2015, 02:37 PM   #3
Average Joe
MrJoe's Avatar
Talking about the Bigfoot levelers, I prefer to use mine manually. It tends to lift the tires off the ground in automatic.
Joe and Karen
2014 Sunseeker 2450sf
Southern Maryland and Beyond!
MrJoe is offline   Reply With Quote
Old 01-24-2015, 02:42 PM   #4
If you are talking Bigfoot levelers, automatic is easier to use and works in most campsites that are fairly level. The only time I would use manual would be just to stabilize versus level on a hilly spot.
SkipnTerri is offline   Reply With Quote
Old 01-24-2015, 03:41 PM   #5
Hoglou's Avatar
Control the control
Control method varies with me. But I can suggest a plastic box from wallyworld for the controller. It is clear plastic with a lid that has green latches. The box lid keeps the controller centered in the box. Made by sterile.
Hoglou the DH (01.01.21 done and retired)
BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 01-24-2015, 03:49 PM   #6
What's the purpose of the box? And where does the excess cable go?
Old 01-24-2015, 03:57 PM   #7
We use mostly RV parks, so sites are typically level and I still level myself. I would use this mostly for stability.
Kristina
Old 01-24-2015, 04:56 PM   #8
Hoglou's Avatar
I stow it and the cord behind the drivers seat, with other goodies. The box does what a the box is for, keeps it safe. I may lean a tad towards over organized, but everything in the coach has a home and a stowed condition. When I travel I like to know what I have and where it is at.
Werid, I know....
Old 01-24-2015, 06:21 PM   #9
Werid, I know....
Assumed the box was for protection. Good idea especially with pets and youngsters. Don't know why FR couldn't find a place to mount it.
Old 01-25-2015, 02:57 PM   #10
Motorized GM
We used to mount it in the dash area and Ford balked at that. When we were looking for a place we had a retail customer say it would be great if it was mounted on a cord so that if you needed to manually level the unit you watch them come own.
In the end, not many people do that apparently so we're just going to move the controls to the entry way where it is a cleaner look.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
bclemens is online now   Reply With Quote
Old 01-25-2015, 03:05 PM   #11
That'll work! And I'm sure future buyers will be glad for it.
Old 01-25-2015, 04:27 PM   #12
JimOneil43's Avatar
Great, Brian. Do you know when that change will be phased into production?
JimOneil43 is offline   Reply With Quote
Old 01-25-2015, 04:29 PM   #13
Motorized GM
Its a running change. Some floor plans are already coming that way. Not sure which ones got done first.
Old 01-25-2015, 04:36 PM   #14
Just my 2 cents worth, but I like to be able to stand outside with control box while doing manual level and look at side of MH.
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 01-25-2015, 07:55 PM   #15
Regarding auto or manual…
I have the 4 pump auto system done aftermarket at Quadra in Michigan.
After a couple years of use, if I had to redo, I probably would have opted for the 4 pump manual system (although, if I remember correctly, the 4 pump auto system was only a few bucks more versus the 4 pump manual system).
I'd definitely make sure to get 4 pumps vs 1 central pump. For one thing, there are fewer lines running underneath which can only be a good thing. Also, the warranty is better. 4 pump systems come with lifetime cylinder, 2 year parts, 1 year labor. Central pump systems come with 1 year parts & labor.
I find that the auto system tends to forget the "true" level. So you're either re-calibrating every so often or operating in manual mode.
Also agree with the poster above who said auto mode tends to raise the coach more than needed. So, per your comment above that this is mostly for stability vs leveling, I think operating in manual mode (regardless of whether you buy an auto system or not) may be best. Lower to the ground = more stability.
Hence, a 4 pump manual system is fine - unless, as I said, that it's just a few bucks more to upgrade to 4 pump auto system.
Hope all of this makes sense - if not, send me a note back.
P.S., I'm a former hockeytown-er
paulmlac is offline   Reply With Quote
Old 01-25-2015, 08:34 PM   #16
Thank you, that was very helpful! Mine also be done at Quadra, and I believe the difference is about a thousand dollars. But I've been looking at many RV things this weekend.
Once a hockeytowner, always a hockeytowner! lol
Kristina
Old 01-26-2015, 08:58 AM   #17
Motorized GM
Yes, see there. Problem is, for the 1% that likes that and wants that, I have to explain it to the other 99% that think the corded location is stupid.
Sometimes you just need to let the current take you.
Old 01-26-2015, 09:06 AM   #18
Kaadk's Avatar
Easy solution, just make Bigfoot engineer a wireless remote for them. Then you could leave a cradle by the driver, but let it be take outside for those that want to watch.
Old 01-26-2015, 09:14 AM   #19
There you go, simple answer to cord problem. I'm sure FR buys enough Big Foot Levelers to have a voice in what they want.
2014 Forester 3051s
2012 Sonic toad
Old 01-26-2015, 09:56 AM   #20
Just for something to read check the sunseeker forum under big foot control box post You can please some people some of the time but not all of the people all of the time
2014 Forester 3051s
2012 Sonic toad
