Old 09-02-2024, 04:43 PM   #1
Another Lithium/Solar Upgrade Question
2023 27DSE Solera. I'm wanting to upgrade to lithium. In the desire to keep the batteries in the step and get as many Ah as possible, it looks like I can get 2 Victron 200 Ah batteries in the step (I know, expensive). It looks like I would also need to use the Victron Energy Smart BMS 12/200. Would I still need to upgrade the original BMS to lithium. Would I just disconnect the battery 2 wire (from alternator?) from it? Would I need any other Victron components to complete this. It seems like the already installed Way Elite MPPT duo-battery charge controller would not need to be replaced. I know to switch to Li in the breaker box. In early planning stages and would welcome any suggestions.
philanum is offline   Reply With Quote
Old 09-06-2024, 07:29 PM   #2
Mainframe's Avatar
It looks like your rig is like mine, 2021 3010DS, well kinda like mine, I just did an upgrade, I did 2 100 AH in the steps, (I didn't know you could fit 2-200 AH in there) and one more in the next over storage bay. I had to change BIM to the Lithium one so my alternator wouldn't burn up and I had to switch my solar to Lithium and the transformer under the bed had a switch on it so I am wondering if you only need to change you BIM
Here is a link. https://www.amazon.com/dp/B07DY8S815...fed_asin_title
2016 Shamrock 23WS
2021 Sunseeker 3010 DS
Mainframe is offline   Reply With Quote
Old 09-06-2024, 07:54 PM   #3
Thanks for the reply Mainframe. Victron batteries require a Victron BMS which charges the alternator. Just not sure how to bypass the BIM, or if I even need to. Or put a cable from the upgraded BIM to the alternator lug on the Victron Energy Smart BMS 12/200. Or remove the chassis battery cable off the BIM (leave it empty) and place it on the Victron BMS.
Old 09-06-2024, 08:20 PM   #4
Lithium have a BMS built into the battery.
Some motor homes can charge the chassis battery via the BMS and shore power
Find and check what Battery manager / BIM you have...
It may already be Lithium capable LI-BIM ?
https://www.precisioncircuitsinc.com...i-BIM-Rev1.pdf
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is offline   Reply With Quote
Old 09-08-2024, 10:27 PM   #5
This is the 200Ah lithium battery from victron; 2 will fit in the stair. It does not have integrated BMS which is why they require a separate one. The 2 wires coming from the battery hook into a BMS sold separately.
https://www.amazon.com/dp/B08175JHMY...lig_dp_it&th=1
This is the BMS:
https://www.amazon.com/dp/B09P5LTNKH...v_ov_lig_dp_it
I assume I'll need the BMS and the upgraded BIM.
Old 09-10-2024, 09:11 AM   #6
Wow, that's quite expensive for a LiFePO4 battery without a built-in BMS. I guess it's designed for more advanced setups. I wonder if two Group 31 200ah batteries with built-in BMS would fit in that space?
Saluda is offline   Reply With Quote
Old 09-10-2024, 04:17 PM   #7
Saluda, I searched and searched and measured and measurmeasured. Couldn't find any. Would much rather go that route if possible
Old 09-12-2024, 03:44 PM   #8
I will do some measurements and check in with big beard batteries to see if they have any custom solutions. I am interested in what they have to offer.
Old 09-12-2024, 04:02 PM   #9
I am of the opinion that it’s always better to buy the best you can and only cry once rather than crying twice when the system doesn’t work.
Victron is top notch and no, they don’t have a built in BMS on the batteries you are looking at. The external BMS will perform better and just work better overall. They are not the cheapest you can get for a reason
I would also say it is worth looking at Mastervolt as well. They are a step better in my opinion and have much better tech support if you need it. Understand that I work for a dealer for both but don’t sell victron as a first choice only because of Victrons weak support and the Masterbuss monitor system is much more user friendly.
MGD1961 is offline   Reply With Quote
lithium, question, solar, upgrade
