Originally Posted by BehindBars
There is really no need for speculation or 10 minute tests. The OP has a 2023 Sunseeker model and the documentation is readily available: https://forestriverinc.help/#/forest...ultiple-709236
The connecting of the chassis and house batteries is done by the BIM in the Battery Control Center, typically located in the coach entry stepwell. The signal from the emergency start switch on the driver seat base, referenced as the “dash switch” in the attached schematic, signals the BIM to interconnect the batteries momentarily.
On my 2020 Sunseeker, with standard driver seat, the emergency start switch is located on the left side of the seat base, much the same as the OP’s. An additional feature I think no one has mentioned, is that it appears it may be possible in some cases to use the emergency switch to start the on-board generator via help from the chassis battery/alternator, in the event the house battery(ies) are too weak.
That's the one... you found it for me, just could not remember what it was callled
The switch is used to override the automatic operation of the BIM
send a signal to BIM to connect the batteries
a second signal to BIM to disconnect them
From the manual
Operation:The Battery Isolation Manager opens and connects the two 5/16” copper terminals by means of a sliding contact.
Each time BIM changes ON/OFF state, the contact instantly switches.
The BIM remains in the ON or OFF State, without coil power
The switch controls the on/off state and the sliding contacts move to either connect or disconnect.
not 100% sure if the automatic 1 hour timer is activated when you combine.
more than likely is
Hate the wording of that manual BTW
