Old 04-20-2016, 01:11 AM   #1
Sagecoachdriver's Avatar
Anyone add Skid Wheels on the Rear?
We've been bottoming out leaving a few driveway and the "V" shaped welded on skid is getting a work-out. Not sure if it can take many more. Have any of you had any luck with either the bolt-on or weld-on skid rollers? I do keep between 70-80 psi in the air bags depending on whether I have the bike and trike on the hitch.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 04-20-2016, 11:57 AM   #2
I actually had the "V"removed rather than adding the wheels on.
Rossriley is offline   Reply With Quote
Old 04-20-2016, 01:56 PM   #3
HopHed's Avatar
I added them as the skid was almost worn through. I got the metal bolt on wheels. Works great but at some point will have to replace again but will be a ways down the line.
Never thought of taking the "V" skid off completely as noted above. May do it when the wheels wear out and see how it works on our driveway.
1978 Ford Rollalong
2004 Fleetwood Tioga 29V
2016 Forester 2861DS (11-13-15)
HopHed is offline   Reply With Quote
Old 04-20-2016, 03:22 PM   #4
HopHed-Any chance you can post a photo?
Old 04-20-2016, 03:35 PM   #5
HopHed's Avatar
Each side. The left was tight with the trailer wiring harness.
1978 Ford Rollalong
Old 04-20-2016, 04:55 PM   #6
Did you get them local? How thick are the shims?
Old 04-20-2016, 04:58 PM   #7
HopHed's Avatar
Amazon for about $80.
1978 Ford Rollalong
Old 04-20-2016, 08:06 PM   #8
Saw some on Amazon. Did you get the 2 1/2" or 3" and the U Bolts don't look as long as yours? Did you use something from Lowe's or HD?
Old 04-20-2016, 08:19 PM   #9
Attachment 105554
Attachment 105555
From your Pic it looks like you just Added 2+" to Early "Touchdown"? Is this Not going the Wrong Way for a solution? Youroo!!
Old 04-20-2016, 08:27 PM   #10
Why not mod the V by cutting part of it off and adding a flat and add the wheels to the flat?
Old 04-20-2016, 08:36 PM   #11
HopHed's Avatar
The picture is deceiving from the angle. Only added about 1/2". I'm thinking to cut off the "V" brace and then raising the wheels about an 1". That should eliminate most of the drag on the back.
1978 Ford Rollalong
Old 04-20-2016, 08:40 PM   #12
HopHed's Avatar
I think it is the 3" bolts. Used nothing else other than some wood shims to get it tight all around. 2 1/2 probably would have worked better.
1978 Ford Rollalong
Old 04-20-2016, 09:57 PM   #13
Here was my solution to our 2000 Four Winds tail dragger: A ball mount was dissected, and the square wall welded to the roller wheel:
Mounted:
This works fine unless you are towing. We had a roller that was pinned below the receiver, but it acted like an anchor on soft surfaces. Got lots of stores...
Help that hopes!
2016 Sunseeker 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 04-21-2016, 01:20 AM   #14
HopHed, I see the issue with the receptacle on mine. Looks like I need about 2" of shim like yours to clear the V skid. I see there is a pair with caster wheels that are 4" and mounted would just clear the skids. Plus they are designed if turning instead of going straight. Most of the driveways I scrape when I need to start turning. Can't always pull straight out of a gas station or market parking lot. But then we had some on vehicles at the studio and they were always ended up bent!
Old 04-21-2016, 07:57 AM   #15
HopHed's Avatar
Sounds like the swivel type should work. You may also want to think about mounting it just to the right of the wire harness plug. Looks kinda funny being offset from the right side but the plug is no longer a factor in how high to mount it. I changed mine last night and raised both 1/2" which is now just below the skid 1/16". I will see how it goes.
1978 Ford Rollalong
Old 04-21-2016, 08:07 AM   #16
Old Enough to Know Better
gasman6674's Avatar
I used these on my previous V Cross, Reinforced the frame and welded on.
They worked very well as I drug every time I pulled out of my drive. I don't need them on current rig as its high enough not to drag
Name:	drag wheel 2.JPG
ID:	105619   Click image for larger version
Name:	drag wheel 3.JPG
Jim & Debbie England
Do you have Gas? 2015 F350 6.2L CCLB DRW 4.30 axle.
2020 Keystone Cougar 364BHL ,Gone 2012 Yellowstone Ridgeline 34RLT Fifth Wheel
gasman6674 is offline   Reply With Quote
Old 04-21-2016, 08:18 AM   #17
BendOrLarry's Avatar
I have the swivel wheels mounted on my rear hitch on my 2860ds motor home. They are very hard plastic, with roller bearings and swivel. I have a steep transition on my driveway and the "V" skids always dug into the asphalt. I may end up shorting the "V" skids a bit and see if that helps because the wheels actually stick below the "V" skids by about an inch, which means I'm actually lifting the rear of the coach a bit when they make contact.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
BendOrLarry is offline   Reply With Quote
Old 04-21-2016, 11:08 AM   #18
Careful measuring of the hitch frame and HopHed's photos suggests that the swivel roller won't have the clearance because of the hitch receptacle. That really only leave getting the one HopHed got.
HopHed, Amazon has a few, do you have the part number that way I know it will work?
Old 04-21-2016, 11:22 AM   #19
HopHed's Avatar
This is the one I got. Funny, I looked at this this morning and price was $80. Looks like big price drop. The 3" is the size of the U bolts which is actually too big for the 2 1/2" hitch mount. I had to shim it 1/2" to make it tight so it would not move. You may want to consider the 2 1/2" model unless you don't mind shimming it in front and bottom.
Ultra-Fab 48-979018 Hitch-Mount Solid Steel Rollers - 3" Hitch Bar
by Ultra-Fab Products
List Price: $94.80
Price: $60.01 Free Shipping for Prime Members
You Save: $34.79 (37%)
1978 Ford Rollalong
Old 04-21-2016, 12:00 PM   #20
List Price: $94.80
Ok, you bought for 3" hitch bar not 2 1/2". That makes sense now.
But isn't the height adjusted lower with the shims the correct height to clear the V skid?
wheel
