Old 11-08-2017, 06:19 PM   #41
A32Deuce's Avatar
I pulled our couch out and had extra padding and recovered with better material. 100% better now. The material looks like an old barber chair. None of the braces hurt your butt now!
A32Deuce is offline   Reply With Quote
Old 06-12-2018, 10:49 AM   #42
rblack22 is offline   Reply With Quote
Old 06-12-2018, 09:07 PM   #43
jkoenig24
ALL the OEM furniture in my 2015 Dynamax DX3-37RB was BEAUTIFUL eye candy. Sadly, the ONLY chair that was even close to being comfortable is the barrel chair next to the entryway. It's bolted to the floor so it can accommodate a seat belt. It's almost under the TV so, it's useless for TV viewing. The year after I bought my DX3, I has all the other "eye candy" pulled out and replaced with truly comfortable furniture. The small couch is now a very comfortable swivel recliner and, I have a trestle table with two real chairs instead of the cramped dinette. The POS Serta mattress has been replaced with a thick foam mattress that is super comfortable AND, is 60" wide (I can use standard queen sheets instead of loose-fitting king sheets). All of these changes were done at ProCustomInc in Elkhart, IN. The staff at PCI do NICE work!
jkoenig24 is offline   Reply With Quote
Old 06-15-2018, 11:27 AM   #44
i have a 2015 Sunseeker 2800GS. i have a jacknife couch which i want to replace. if you could share that info i would appreciate it. mine is on a slide. not sure what i can change but i definitely want two recliners instead.
pzrose is offline   Reply With Quote
Old 06-15-2018, 03:04 PM   #45
Garrette's Avatar
This has been done on this forum. I myself have done it. The slide can support two wall hugger recliners. Some opt for swivel, some with recliner couch. You couch will remove easily, remove arms, unbolt from floor, tip over and remove back. Very easy to do. Measure your base width and start shopping. The wall hugger S will need about 3" clear of the wall. With the backs removed, they will go through the door. Close but doable. Just be careful. You will sit up higher but watching TV will be easier. Will look funny until you get used to the new look. Mind turned out to our liking. I have a thread for the install.
2014 Sunseeker 3170 DSF
Dorothy, Garrette and Miss Bella.
Retired and having fun.
Garrette is offline   Reply With Quote
Old 06-15-2018, 03:21 PM   #46
Garrette's Avatar
3170 Couch Swap
http://www.forestriverforums.com/for...d.php?t=129011
Old 06-15-2018, 03:25 PM   #47
Garrette's Avatar
Dinette to double recliner modification w/pics
http://www.forestriverforums.com/for...d.php?t=121842
Old 06-15-2018, 03:40 PM   #48
Garrette's Avatar
This was my favorite. Just not what we wanted. Even though it was not done on a slide box, it is doable. I looked at it, using the seatbelts as anchors in transit.
2251 dinette transformation to "lounge"
http://www.forestriverforums.com/for...ad.php?t=94707
