Originally Posted by Murphy55378
I have a Sunseeker 2800QS and it appears the tank heaters do not work. Rocker switch light does not light up. We have never used them before so I don't know that they ever worked. Dealer said to check the fuse as it is the most likely cause. Problem is that none of the fuses are marked for the heaters. Is it possible that the fuse was never installed? Can someone tell me what location their fuse is in? I did try them when it was below 40 degrees as I know they have a built in thermostat and nothing.
They switch on ours will light up when we turn it on no matter the temperature, but the pads themselves are supposed to only turn on when the temperature is below 40* (or so we were told
The fuses can be confusing. I would go out and check ours, but it is in the shop for some repair work right now. I would just use a fuse tester and check all the fuses. Also, if you have extra 15 amp fuses and there are empty slots in the fuse panel, just put one in an empty slot and try the switch. I'd also check the control panel and see if the switch is wired up.
Just some suggestions...
Happy travels...
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
