06-02-2018, 03:10 PM
Atwood water heater not working
New 2800QS on trail run. Every thing works but the Atwood water heater. Is there something more than chosing electronic or gas?
06-02-2018, 03:23 PM
Have you made sure the bypass valves are in the correct position in case the RV was winterized. This is a common occurrence.
 2011 Flagstaff 831 RLBSS
Most people write congrats because they don't know the spelling of congrajulashions
06-02-2018, 03:26 PM
06-02-2018, 03:43 PM
Certified Curmudgeon
Do you know where the bypass valves are?
To answer your Q directly, No. Its just that simple when all the prerequisites are met.
Welcome to Lake Wobegon where Justin and David utilize abductive reasoning to help solve F/SS issues.
Happy Trails and Remember the Pequod.
06-02-2018, 03:44 PM
No
06-02-2018, 03:47 PM
There is an access panel on the bottom front of the kitchen cabinet or you can take the bottom drawer out under the cooktop.
06-02-2018, 03:48 PM
Note: If you fired it up and have no water in it, you may have to reset the overtemp safety.
06-02-2018, 03:54 PM
Thanks for the help!
06-02-2018, 04:02 PM
NeX Let me know what the outcome is please.
06-02-2018, 04:15 PM
Its going to have to wait till I get home tomorrow. With the drawer out can't tell on/off on the valves, and the cover takes a hex head driver, which I don't have with me... : (
06-02-2018, 04:22 PM
Now you know what to add to your RV list.
06-02-2018, 08:36 PM
Its not a hex head. Standard square drive for 95% of the screws in the coach. You can use a #2 phillips but gently because there is not a lot of groove there. Also, when you put them back in I suggest finger starting and then only finger tight.
06-02-2018, 09:48 PM
Found a t drive at a nearby auto parts store. Was able to access and turn valve's correctly. Hot water!
Thanks everyone
06-02-2018, 11:49 PM
Thanks everyone
Ahhhhh Good news for sure. FWIW, your dealer should have done that on PDI.
