09-19-2016, 05:37 AM
Automatic levelers on shorter RV?
We are considering purchase of 2430S and were told by a salesperson that the dealership never orders automatic levelers for the shorter class C units because they were not useful on that size RV.
We don't have any experience with this and hope to learn whether the automatic leveling system is worth it and useful on a 25-26' class C. Thanks.
09-19-2016, 09:54 AM
Sounds like a salesman answer to me! I have never had a class C but I would have loved auto level on my shorter fifth wheels. I bet the dealership is just trying to keep the cost down. I would investigate other dealers and/or see about ordering a unit with everything you want. Good luck!
Scott and Liz - Southern NM
09-19-2016, 10:07 AM
We have a 24' Travel Trailer and while it's a shorter rig, I'd personally love self/auto leveling. We currently have sticky levels on the front and side of the coach and then we use the level jacks with the yellow lego type blocks under to level as needed and then the front stable bar we move up or down as needed (this piece is automatic). If I could push a button and have the leveling done for me that would be awesome.
09-19-2016, 04:13 PM
RETIRED AND LOVING IT
Our rig is only 2+ feet longer and I wouldn't be without my Bigfoot levelers.All sites are different and unless it's a poured pad you'll need leveled. Also will stabilize your rig
Mary and Me 😷😷 Stay Safe
2015 2650s "Finally"
2015 Jeep Cherokee
2016 Ford Race Car Red 350HD Diesel Cargo Van HR DRW EXT "Red Roamer"
"I am in the prime of my decrepitude"
09-19-2016, 04:26 PM
You can always try it without, and see how it goes. They can always be added later.
Being level is more critical if you are using a Propane/Electric refrigerator. I don't run my refer, and I don't mid being a bit off-level.
YMMV
09-19-2016, 04:32 PM
Citrus County, Fl.
DW's cousin has the 2251 SLE which i only 24' and did not come with them. After a trip to Alaska he had the BigFoot 4 point automatic levelers installed. He had downsized from a 36' Bounder and really missed them.
 2016 Forester 3011DS
2017 Toyota Corolla SE toad
99 Terry 31G
09-19-2016, 04:33 PM
First hand experience... We have a 2300 with factory bigfoot jacks. Yes, I would get them again, and again.
Hoglou the DH (1231 and done!)
BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
09-19-2016, 04:36 PM
I would not own a TT or anything else without either the level-up, big foot or the electrical auto leveling system. I had it added after, It's alot cleaner installation if you get it done when being built....
Coachmen M/H
Concord
2018 / 300 DSC
09-20-2016, 03:01 PM
We have the Big Foot automatic leveling system on our Leprechaun 220QB and love it!
09-20-2016, 04:29 PM
Dealers keep the list price down to get more people to look. An auto level system will cost more later than if factory installed most every time.
I place 2 plastic pads under each foot to keep them clean, then press a button. The coach is level and Stabil. No boards and no levels. Anyone with a bad back, bad knees, over 50, or that does not enjoy wasting time with work should have auto level. I would not own any coach without it.
I unhitched, connect electric (not required) and punch the button. It does the job before I have the water hose out and connected.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
09-20-2016, 05:30 PM
Our Lexington 283GTS came with HHW levellers and we love it. Won't be without them again.
Phil, Heather & Olaf the Boxer
Ontario Canada
Lexington 283GTS
09-20-2016, 06:12 PM
Our 2014 2500TS cam with the Big foot system and it is great.
Almost all sites are not level and with the touch of a button you do not have to run around and check the leveling of the unit. On manual control for example , if the front end is down just put up the two front jacks and you are done.
time saver and great system. just put a 2 x 6 piece of wood under the feet before you put them down as they will tend to sink into hot pavement or a wet camp site..
Brandon2
2014 2500TS
Sun Seeker
09-20-2016, 06:22 PM
Looks like the consensus is that auto levelers are fantastic on any size rig!!! I know we love ours. 2jcsontheroad, find a new salesman and get what you want! 😁
09-20-2016, 09:30 PM
I, too, was on the fence about adding them to the order when we ordered our 2861, but I am sure glad I did! Like others have said, the stabilization alone makes a huge difference, and the 10 minutes saved not playing with the giant legos is just more time on bottle (wine that is). There is also a certain satisfaction that comes from watching our empty rig contort to perfect level like a posessed low-rider! Not sure if it would be a deal breaker for me on an outstanding deal, but I would recommend to anyone that they opt for the levelers if it is an option.
The next time I do a one-nighter I am going to try not to push that auto level button (going to be tough) and see what a full day without being level and stabilized is really like. Sadly, it looks like it may have to wait until Spring as last weekend was a little colder (34 degrees) than ideal for us.
Good luck!
2017 Forest River Forester 2861
2016 Jeep Cherokee Toad
09-21-2016, 07:59 AM
Levelers
I installed HWH levelers on our SUNSEAKER 3010ds & would n't be without them. I went to the factory in Moscow, Iowa &plugged in, in the sho0 at 7:00 the next morning and was home in Des Moines by dinner.
09-21-2016, 08:31 AM
Chief tinkerer
What they said, esp CapJohn about dealers. Also, first time you roll in after a long drive in the rain and all you have to do is hit the button, you'll be glad you have them.
Gary
 2017 SunSeeker 3010DS
09-24-2016, 06:00 AM
Order it with it!
YMMV
We were quoted $7500 to add it later, $2250 to order it with it. No brainer there.
2017 2501ts Forester 27ft
09-24-2016, 10:00 PM
Everybody that stated they love the BigFoot is right on. Not only will you love them for your use it will help in the resale if needed. Yes a great idea to get them.
2014 Forester 2301 - Chevy
