Originally Posted by oldnewguy
Have a 2013 sunseeker 3050s and went to roll out awning and nothing, checked to have power at switch and do, but unit fails to roll out. Is there a inline fuse in the system. we have power outages during the winter and that could of blown the fuse. checked the cabinet with all the tv stuff but no fuse there nothing outside and can not get at motor as unit will not roll out .
Did you check for power at the wires at the awning arm/motor or where they go through the wall when someone depresses the switch?
Fuses typically protect the feed wire and if you have power at the switch the feed is OK. There would be no downstream fuse going to the motor unless someone added something aftermarket.
