Old 08-20-2016, 11:17 AM   #1
Awning LED lights failing
LED awning lights seem to be failing after only 2 years.
There are 3 sections of LEDs that are burnt out.
Anyone else experience this problem?
jst3 is offline   Reply With Quote
Old 08-20-2016, 02:03 PM   #2
Wandering's Avatar
Yes. Mine are just two years old. If left on some seem to come bad on but not all. Bummed!
Forester 2451s
Happy Campin!
Forester 2451s
Wandering is offline   Reply With Quote
Old 08-20-2016, 02:09 PM   #3
Broadway Joe's Avatar
Had the same thing happen to mine, they replaced them at the frog rally.
Joe
2015 Wildwood 27RKSS (now sold)
2015 Silverado 2500HD Duramax
Broadway Joe is offline   Reply With Quote
Old 08-20-2016, 02:24 PM   #4
Wobbles's Avatar
I am on my second season using mine and have the same issue. At this time the majority work. I would not mind a few more going out as that baby is way to bright at night.
It is a shame that it is failing. DW felt down when another camper pointed it out. But, now the DW sees it as an item to fixed.
My plan for the day it gets too bad is to replace it with a strip that can change colors and brightness.
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 08-20-2016, 02:37 PM   #5
I bought my RV used and it was 1.5 years old and the lights were out. The RV lot put new ones on that failed within a couple uses. I have yet to replace them. I have seen some YouTube videos on them so may just get some and do it myself.
2021 Micro Lite 25FKBS
2021 Ford F-250 XLT CCSB 4wd w/ 6.2l and 6 sp. transmission, 3.73 locking axle
gmacklem is offline   Reply With Quote
Old 08-21-2016, 12:40 PM   #6
michael621's Avatar
About 1/2 of the string has failed after 6 or so uses. Failed under warranty, but was not worth the 250 mile round trip to the dealer. I'll replace it "someday".
2022 Prime Time Crusader Lite 28RL
2022 Chevy Silverado 2500 Duramax/Allision
michael621 is offline   Reply With Quote
Old 08-21-2016, 12:53 PM   #7
Yes, after 3yrs. 2014 Sunseeker 3010DS, replaced them and now much better LED lights
goots is offline   Reply With Quote
Old 08-21-2016, 12:56 PM   #8
Here the picture
Old 08-21-2016, 01:15 PM   #9
Rick54's Avatar
we have a 2014 3100SS, have the same issue, the light strip starting failing in the 2nd season.
Goots - what did you install & of course where did you purchase it?
Rick54 is offline   Reply With Quote
Old 08-21-2016, 01:37 PM   #10
Replaced the whole strip and had it hard wired to the existing wire. Brand name Diamond Daylight White 16' LED Strip Light Kit. Install by local RV Shop, I just had a knee replacement so the shop did it for me. Lights cost $90.00 but worth it much more bright light then the original ones. 🖒👀🖒
Old 08-21-2016, 01:40 PM   #11
Purchased they light at the local RV Shop, maybe you can find them online good luck.
Old 08-21-2016, 01:41 PM   #12
opps " these lights"
Old 08-21-2016, 01:43 PM   #13
Rick54's Avatar
wow, that easy huh, thanks for the quick response. Now forward to the internet an see what I can find. Thanks again
Old 08-21-2016, 02:12 PM   #14
No worries, Happy Rving
Old 08-21-2016, 02:53 PM   #15
Niel's Avatar
The lights on our 2650s were mostly burned out when we got it used. Replaced the whole strip. Works perfect now. Montreal led. Around $100.00
Niel is offline   Reply With Quote
Old 08-21-2016, 03:17 PM   #16
Mine were going bad when we got the new trailer home,dead spot about a foot in.Chinese lights from lowest bidder.Would hope for better quality control.
JR Smith is offline   Reply With Quote
Old 08-21-2016, 03:45 PM   #17
Same issue with my 2014 Surveyor Select during the second season of use. I have 2 sections of abt. 3-4 inches with dead lights. All worked when winter stored in 2015.
Rmstack is offline   Reply With Quote
Old 08-21-2016, 05:36 PM   #18
Same here junk . Put new set in put clear silicon over them this time so far so good. Fingers crossed
retired on a mountain is offline   Reply With Quote
Old 08-22-2016, 06:20 AM   #19
Wolverine 1945's Avatar
We found some burned out when we did our walk-thru on our 2013 Sunseeker !!!
Wolverine 1945 is offline   Reply With Quote
Old 08-22-2016, 11:04 PM   #20
You can get them on Amazon for about ten bucks in several colors. It's a very easy install. Pull the old ones down, cut the two wires, peel and stick the new one, attach the two wires, and new lights.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
bobneal69 is offline   Reply With Quote
awning, led, light
