You have a problem, but it’s an easy fix. LCI has this response:
“Thank you for the requested information. It sounds like the wires for the canbus connection are wired to the power wires. You will need to cut the canbus wires, which go to pin 11 and 12. It's a wiring issue. Essentially, there are four wires hard wired together, which two of them should not be. These wires need to be found and the wires that go to pin 11 and 12 need to simply be cut to that connection.
I would suggest having a service center check for this and find the correct wires to cut."
Lots of other good info in this thread:
http://www.forestriverforums.com/for...ng-174828.html
