Back Up Camera Bad Connection
I have a 2018 Forest River Forester 2861DS. The backup camera system appears to have a bad connection somewhere. The backup cam screen (in radio) will become fuzzy or go black. The side cameras all work with no problem. I spent some time troubleshooting the system and believe the problem is a bad connection or cable. I pulled the cable at the backup camera and the picture cleared up. I was not able to find any connection before the cable became tight and I don't see any access to inspect this. I think there is a pigtail from the camera that connects to a 60' cable but I cannot get enough cord out to be able to see this. There is only a small hole where the cable goes into the MH. Also, when I pull the cable (at the camera), it appears to go to the right, but when I look under the MH I think the cable goes to the left in a plastic conduit.
Has anyone run into this and found a way to get access to the connection? I can't explain why the cable seems to go the opposite direction at the camera to where it goes on the bottom of MH. The camera stopped functioning again yesterday about 30 miles down the road, so I'd like to fix this for real. Any help would be appreciated.
____________ 2018 Forest River Forester 2861DS
