Old 10-27-2019, 09:01 AM   #1
Sagecoachdriver's Avatar
Bathroom Vanity counter top swelling and dissolving
My bathroom vanity counter top has begun swelling at the front underside edge underneath and is dissolving leaving particles on the floor. I don't know how water would get under there to cause the swelling, but it has. It only a matter of time when I will need to replace the top. I haven't checked with FR to see if the still have them in stock.Has anyone out there had a similar issue with the vanity top? I suppose I could make one with laminate. Photos to follow later today.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 10-27-2019, 09:21 AM   #2
RedLdr1's Avatar
Is the bathroom sink mounted over or under the counter top? I've seen under mounted sinks cause the problem you're describing due to poor sealing.
Wayne
2024 Sunseeker 2150SLEF / Ford E-350 Due Off-line 11 April 2024.
RedLdr1 is offline   Reply With Quote
Old 10-27-2019, 02:20 PM   #3
Here are photos
ID:	218168   Click image for larger version
Old 10-28-2019, 09:35 AM   #4
Wandering's Avatar
Yes mine is doing the same. Kitchen sink and sink inserts as well. Kinda frustrating but I’m inclined to replace with some kind of solid surface.
Happy Campin!
Forester 2451s
Wandering is offline   Reply With Quote
Old 10-28-2019, 09:41 AM   #5
Commercial Member
ES_FR's Avatar
Sagecoachdriver,
We would be happy to assist you with your 2016 Forester. Because your ongoing satisfaction is very important to us, we invite you to contact Kary Katzenberger in our Customer service department through the following personalized and direct link: http://www.forestriverinc.com/Direct...78559932768256.
This direct link is provided for your convenience in order that we may resolve your concerns as quickly as possible. We will strive to respond to you within 24 hours of receiving your correspondence.
Respectfully,
Forest River
ES_FR is offline   Reply With Quote
Old 10-28-2019, 12:00 PM   #6
Originally Posted by ES_FR View Post
Sagecoachdriver,
Respectfully,
Forest River
Thanks, I have chatted with Kary in the past and was going to send him and email. He has been very helpful!
Old 10-28-2019, 01:42 PM   #7
Kirk S's Avatar
Newer laminate counter tops wrap around and under the entire front edge instead of stopping at the bottom front for this reason exactly.
Several of our older tops in our sticks & bricks homes have had this issue.
Kirk
2017 Forester 3051S
Kirk S is offline   Reply With Quote
Old 10-28-2019, 01:55 PM   #8
When a lot of water gets on the vanity top some will run over the edge and at the bottom the surface tension of the water will cause it to "curl" around the bottom edge. It then gets into the unsealed particle board.
Before replacing try this:
Get the area really dry. Set a heater up so it blows warm air over the area for a day or so (far away that it doesn't overheat laminate).
Take a sanding block with some medium grit sandpaper and sand off the swollen wood so it's level with the surrounding wood and even with the lower edge of the laminate.
Apply some clear Varathane or other good water resistant wood finish to the area. First coat should soak into the dry wood so keep applying as it's sucked into the wood until your brush strokes stay "wet".
Let dry.
Another product besides Varathane that will work well is Minwax Wood Hardener. Stuff is real thin, is sucked into wood that's been damaged like this, and forms a resin reinforced wood product out of the more sawdust like area you have. Can then be coated with Varathane or a paint of your choice. Warning, the Minwax product is rather volatile and you want lots of ventilation or you'll end up feeling like a glue or paint sniffer.
To help prevent future issues, just put a towel folded lengthwise along this area of the vanity while using. You'll want to keep the water from flowing down the front of the cabinet and sitting on the floor as well.
BTW, I have the same issue with water at my sink. Sink and counter edge are small and it's hard to not get some "splash" when washing hands/face.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
TitanMike is offline   Reply With Quote
Old 10-28-2019, 03:13 PM   #9
I was sorely disappointed in the material FR used for the countertops. I had swelling in the kitchen countertop last summer, I got angry.
So I fixed it:
with new Corian.
Kitchen:
We had a 2000 Four Winds prior to our 2016 Sunseeker. That unit currently belongs to a friends, and it has never had countertop issues. MDF should never have been used for countertop material.
2016 Sunseeker 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 10-29-2019, 10:41 AM   #10
MDF
So I fixed it:
It's a often a chipboard (like OSB) rather than MDF, as it is in the OP's photographs. I just replaced a 1965 vanity in my stix-and-brix that was doing that, with cultured marble.
In 1995 I renovated the kitchen there. The new "Formica" melamine resin countertops had the same material. Following the advice in the dishwasher installation guide I used several coats of Deft, a bartop finish, on the underside before setting the dishwasher in place.
Larry
Larry-NC is offline   Reply With Quote
Old 10-29-2019, 04:56 PM   #11
Mine was certainly not OSB (Oriented Strand Board) nor particle board - it was MDF. The counter top in the OP's picture looks just like mine did, though theirs are swollen much like my kitchen countertop was.
Old 10-29-2019, 05:03 PM   #12
Sealed
Definitely should have been sealed. I wonder why that was omitted.
Larry
Old 10-30-2019, 10:02 PM   #13
Sagecoachdriver,
Respectfully,
Forest River
t
Still waiting for the reply.
Old 11-08-2019, 08:57 AM   #14
To date, I have not received a reply to my email to Kary. ES_FR, can you look into it please?
Old 11-13-2019, 09:56 AM   #15
Commercial Member
Sometimes those direct contact links go to goofy places. Has anyone reached out?
I can confirm that the top is mdf. Pretty common. In the old days, it was a high pressure laminate top and water would get into the T-molding and/or banded edge. This new "Thermo-Form" counter looks better and no exposed seams.
TitanMike has the repair right...my only suggestion,...sanding, could be a mess with MDF. If it were me, I would use hand wood planer or razor blade to shave that area. Then seal as he mentions.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (instead of asking privately) so others can benefit from the answers.
Subscribe for "How To" videos and updates https://www.youtube.com/c/DynamaxRVs/
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 11-13-2019, 10:34 AM   #16
Yes, Kary answered my direct email the other day requesting some information. Awaiting further reply now. Thanks
Old 11-13-2019, 10:45 AM   #17
Commercial Member
Perfect.
bathroom, forester, roo
