Check the manual for the inverter mounting position. Vertical is not allowed per the manual due to cooling fan issues. I doubt it really matters in reality but it may impact warranty if you do happen to have a failure.
When I was installing my 3000W inverter charger, I asked them about mounting on it's side so the fan shafts are still horizontal and they still said no, so it's just CYA for them.
I have my DC-DC mounted vertically like you. Don't forget to set the dip switches not just for battery type, but for charging voltage. I forgot the voltage and was not using the max for my batteries. I noticed a slight improvement in charging time once I up'd that.
2021 Flagstaff 21DS
2015 Silverado 2500HD (overkill but convenient)
Renogy bits: 3000W Inverter/Charger, 400Ah LiFePo4, 40A DC-to-DC
Rich Solar bits: 400W of panels, 40A MPPT
Misc bits: LevelMatePro+, SolidRemote based wireless controlled LED storage lighting
