Be sure the disconnects are rated for at least 200 amps. You don't need that much normally but you do if you use the battery booster switch to start the chassis engine.
Also, if you are boondocking, switch off the antenna amplifier when you are not watching TV. It takes a little current constantly. If you boondock much, disconnect the refrigerator "Climate Control" element. It stays on all the time. There are several threads in the FROG forum about it .
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
