Old 05-26-2020, 03:17 PM   #1
texasblues's Avatar
Batteries Draining
I bought two new coach batteries in January 2020 for my 2015 Sunseeker 2800 QS. I always turn off the main power switch when in storage but for some reason the batteries are still drain. Any thought as to why the batteries would drain empty in one month? It appears that everything is off.
texasblues is offline   Reply With Quote
Old 05-26-2020, 03:52 PM   #2
There are some things that are usually still connected when switch is off. Lpg leak detector is one.
Since batteries are new and you intimated that draining has been a problem there is something still connected that is drawing from battery more than just an lpg leak detector.
Try charging batteries fully and then disconnect them. See if issue continues.
"A wise man can change his mind. A fool never will."
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 05-26-2020, 04:32 PM   #3
texasblues's Avatar
Ok thanks
Old 05-26-2020, 05:11 PM   #4
GoneSouth10's Avatar
As TitanMike said, a lot of little parasitic draws on those house batteries (to add to the list: radios with memories, appliances with memory settings, CO2 detector, etc.). Most if not all of these devices SHOULD be on the correct side of the disconnect switch so they should not get power when the switch is OFF, but . . . .
Also, you didn't mention your battery capacity, but there's 720 hours in a 30 day "month". That means just a 0.1 Amp draw (not that much) drains a 100Ah battery of it's usable capacity (50Ah) within three weeks If your batteries are smaller (or perhaps not fully charged), it may happen even faster or with an even smaller draw.
2015 Berkshire 34QS
GoneSouth10 is offline   Reply With Quote
Old 05-26-2020, 05:38 PM   #5
Kanadian Kamper
kenandterry's Avatar
Pick one for your application.
If the circuit is cut off to your batteries, no more dead batteries.
https://www.amazon.com/s?k=battery+d...b_sb_ss_i_5_12
Ken and Terry
2018 Sunseeker 2430S-CD
and if we ever need it, can be pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is online now   Reply With Quote
Old 05-26-2020, 05:40 PM   #6
texasblues's Avatar
It has a red on/off switch. It looks like it turns all off but I guess not.
Old 05-26-2020, 05:50 PM   #7
No. It doesn't turn everything off. You've got parasitic drains (we all do) that can only be turned off by disconnecting the battery at the battery itself.
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 05-26-2020, 06:07 PM   #8
texasblues's Avatar
Understood. Will buy a Battery disconnect tomorrow. Thanks everyone.
Old 05-27-2020, 10:53 AM   #9
Or... just pull off the negative cable when putting in storage.
Mark
Sunseeker 3050s 2017
Markl3050s is offline   Reply With Quote
Old 06-03-2020, 12:17 AM   #10
benagi's Avatar
Or just get a battery tender. Anytime we have our motorhome sitting by the house, I put a battery tender on it. Works great.
1968 tent trailer
1985 Jamboree 23 ft
1997 Minnie Winnie 25 Ft
2016 Forester 3171DS (ordered March & arrived June 2015)
benagi is offline   Reply With Quote
Old 06-03-2020, 12:58 AM   #11
Rockinh's Avatar
Battery Tender
x2 I put one on my bike in the rv garage and it keeps the battery charged all winter, with the RV plugged in to shore power. Plus my bike is in its own garage and doesnt take up any space in the garage at home.
RockinH Bill
2019 Silverback 37RTH
2014 Shadow LQ 3 horse select
2015 Ram Laramie DRW
2012 concourshttps://www.forestriverforums.com/forums/images/smilies/roflblack.gif
Rockinh is offline   Reply With Quote
Old 06-03-2020, 08:53 AM   #12
i had the same problem with batteries draining within a month while in storage. i put in my own disconnect switch that removed all loads and now the battery stays fully charged for months. i think i found five devices in our trailer that we wired directly to the battery and that were not disconnected by the factory installed disconnect switch. they may be small loads but over time they still drain the battery.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
batteries, drain
