Old 11-26-2016, 08:56 AM   #21
World Wide Wanderer
wahoonc's Avatar
Originally Posted by markb422 View Post
So if the converter does not charge your chassis battery when plugged in then your coach batteries do not charge while driving?
The coach batteries do charge while driving. There is a diode assembly that only allows power to run one way, from the alternator to all the batteries, but not the other way. I think the reasoning is that if you kill the coach batteries you still have the chassis battery to be able to start the engine. In most cases there is an override button that will allow you to use the coach batteries to help start the engine if something happens to the chassis battery.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
