Originally Posted by Duckogram
I did the same thing a month or so ago. Suggestions: After removal of your deados you might want to flush out the battery box with a baking soda solution. Rinse n dry. Then I coated the box with flexseal. Heavy brush on so it leveled out.
I had also added a screen over the vent hole to keep critters out. The flexseal will keep the box from corroding and also keep the batteries from sliding.
As for your clamps. Are you the first owner? If not, they may be running to the chassis battery to charge it from the converter charger. Not a great idea but better than nothing. Also could be what Brian said.
Thanks, did the wash out today, letting it do the final dry overnight, will probably put the batteries in tomorrow. Probably will do the flexseal.
We are the 2nd owner, I am thinking that the cables might be for the solar panel that we were given by the previous owner. We have never used it, but during our walkthrough, the previous owner showed me how to hook it up, and now I am recalling that the cables may be for connection to the solar panel.
Thank you for your comment.
