Old 03-09-2016, 10:31 PM   #1
sgtlm17's Avatar
Battery isolator question
This is for a 2016 Forester. The battery isolator has one side connected to the house batteries and the other to the chassis battery. If you press the emergency start switch the isolator opens allowing vehicle to start from house batteries.
Now when you are plugged into shore power does the isolator open and allow the converter to also charge the chassis battery? I am wondering if I should invest in a Trik-L-Start.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 03-09-2016, 10:39 PM   #2
SeaDog's Avatar
On most rigs that I have seen the converter does not charge the chassis battery only the coach batteries. With my Winnebago I leave a battery tender on the chassis battery when I have the rig in my shop.
Retired Navy
2016 Flagstaff 26 FKWS
Old 03-09-2016, 10:51 PM   #3
Not to be a smart ass, but the isolator switch stays in the open position until called upon. My 2016 Forester (MBS) has an isolator switch that closes when the engine runs so chassis and coach batteries charge. It does not close when plugged into shore power, so it does not charge the chassis battery. I installed a push button switch so I could turn on the isolator switch if I needed it to jump my engine. Mine did not have one from the factory.
2016 Forester 2401WS MBS
Life is short...eat the cookie
bob dirt is offline   Reply With Quote
Old 03-10-2016, 02:27 AM   #4
sgtlm17's Avatar
Does anyone have a Trik-L-Start? Opinions? It allows a trickle charge to chassis battery from your house batteries via converter.
2011 Jeep JK Toad
Old 03-10-2016, 08:45 AM   #5
Most BCCs are designed to work both ways. If yours doesn't I would try to figure out why not. The trik-l-start appears to lose at least .5 volts, the BCC isolator solenoid will lose you nothing. It is already there and can do the job if correctly hooked up.
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 03-10-2016, 09:02 AM   #6
sgtlm17's Avatar
Gonna do some testing and check some readings today
2011 Jeep JK Toad
Old 03-10-2016, 10:07 AM   #7
I looked at the manual for the Intellitec BCC. Seems that it would be hard to prevent the converter from charging the chassis battery without going to great lengths as the circuitry that allows the house to be charged by the engine is integral to that function. There are some fuses that might be a problem and I did notice a "removable jumper" on the ignition isolation relay that prevents shutting off the batteries when the alternator is running, which would blow the diodes in the alternator as it would no longer see a load.
Here is what I am looking at.
http://www.intellitec.com/assets/pdf/5301087new3.pdf
2015 335DS
Old 03-10-2016, 11:48 AM   #8
I checked the jump connections under the hood. The voltage did not change when I turned on shore power. I have to assume it does not charge the coach battery...although I could be wrong
Old 03-10-2016, 03:45 PM   #9
Bob dirt,
I think the poster's 2801 QSF is on a Ford chassis. The BCC operates a little differently from the BCC on a MB. I recall Brian Clemens said MB would not let them connect to their electrical system. On the Ford chassis the BCC connects the coach and chassis 12 volt system when the coach's convertor is charging, when the chassis alternator is charging, and when the battery booster switch is pressed. The BCC will connect the batteries only if there is enough voltage, unless the booster switch is pressed. If the coach batteries are low, it won't connect until the convertor has charged them.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 03-10-2016, 03:54 PM   #10
Originally Posted by RamblerGuy View Post
Bob dirt,
I did see he had a different chassis, that's why I wrote "on my chassis".
The way to verify charging is with a DC volt meter. The voltage should go up on the coach battery connections when he turns on shore power. If it does not, it does not charge on shore power. I kinda wish mine did.
Old 03-10-2016, 04:10 PM   #11
Bob dirt,
It's your motorhome. Wire it to charge when you want it to. Use a switch. Maybe the BCC that's installed can do it like the one in Fords and you can add wires to make it work.
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 03-10-2016, 04:17 PM   #12
sgtlm17's Avatar
Yup finished testing. When engine running house batteries charge. Engine off plugged Into to shore power only house batteries charge. I will probably do something to keep chassis battery up. Battery tender, Trik-L-Start, etc.
2011 Jeep JK Toad
Old 03-10-2016, 04:41 PM   #13
Do you have a Ford or Chevy chassis? I can't tell from the photo in your tag. If you have a MB chassis, ignore my comment below.
How long did you wait to read the voltage at the chassis battery after the plugging in the shore line? Our 2011 Sunseeker has an Intellitec BCC, which does not connect the coach batteries to the chassis battery until the coach system is above 13.1 volts for more than 2.5 minutes. I think FR changed suppliers, so yours may work differently, but the concept should be the same. If the coach batteries are low, it may take a while for the system to rise above 13.1 volts. If you don't have documents on your BCC, look on line for it to find out the voltages and timing for yours.
By the way
RamblerGuy
2011 Sunseeker 3100
2016 Ford Edge Toad
Old 03-10-2016, 04:48 PM   #14
Bob dirt,
good idea...I could swap out my momentary switch I installed to a toggle switch and just be careful not to leave it on when not needed.
I'll also look into Trik-L-Start like sgtlm17 mentioned.
Old 03-10-2016, 04:54 PM   #15
sgtlm17's Avatar
Hmm very good info Rambler I will take another look at it
2011 Jeep JK Toad
Old 03-10-2016, 05:10 PM   #16
Not sure either
I measured the chassis battery voltage the other day at the jump start connections too - and got 13.8 volts with shore power plugged in. As a result, I assumed that the BCC relay was closed and the converter was also charging the chassis battery. Probably not a good assumption I guess.
I'm going to call Precision Circuits again tomorrow and see if I can get a better technical description of how the BCC works. Need to talk to them anyway about the fuse size for hooking up the boost/emergency start function. I assume 5 amps is more than adequate, but I'm going to verify.
KatanaPilot is offline   Reply With Quote
Old 03-10-2016, 08:21 PM   #17
sgtlm17's Avatar
As to the question before my 2801 is on a 2016 Ford E450
2011 Jeep JK Toad
Old 03-10-2016, 08:36 PM   #18
You know, that is interesting. I am building a data logger for my Trimetric that records all the parameters and writes them to an SD card for subsequent analysis and evaluation. Surprisingly, I watched the banks stay connected for quite a while after I shut down my generator (converter) or my engine (alternator.) On my older 1997 Bounder, the BCC would keeps the banks connected for a while, but the newer versions seem to keep things connected much longer.
2015 335DS
Old 03-10-2016, 08:37 PM   #19
Bob dirt,
Seems that I read somewhere that was a misunderstanding.
Old 03-12-2016, 02:12 PM   #20
sgtlm17's Avatar
Anyone get a definitive answer on this. I'm going to try to get to coach and do more testing later today
2011 Jeep JK Toad
battery
