Battery Specs 3170DS
Does anyone know how many amp hours or cranking amps the stock coach batteries have in the 3170DS. My 2013 came with two 12V, I don't see a brand name or any specs on either of them.
They seem to die within days of not being used, even when the switch is disconnected. I took them to Autozone to be tested (hoping only one is bad) and was told I need to know how many CCA's they are suppose to put out before they can test them under load.
I figured they should be good for at least 3 years.
