I have looked at the manual and it says shore power will charge the batteries when the batteries are disconnected. The manual shows two options for a battery disconnect. One is a regular rocker switch. Another is a red key in a black box. This is the kind I am most used to seeing. I looked all over and can't find either of these types of switches.
In researching online someone said the switch I have attached a picture of is a battery disconnect. Is this true? If so, what position, On or Off, does it need to be in so the shore power will charge the batteries. If this isn't the switch I need where do I find the battery disconnect.
