Old 05-18-2013, 09:28 AM   #1
Big Foot Levelers Too Low?
Question - My 2013 3010DS came with Big Foot levelers. I like them. Am concerned that rear clearance of aprox 7 1/2 inches above ground is not enough. Even smallish dips in road or entering driveways looks like it will drag levelers. Anyone having issues with this? Help!
Golfmike is offline   Reply With Quote
Old 05-18-2013, 09:37 AM   #2
Only time I have drug mine is when I pull in or out of my garage. Have not had any issues on streets or roads yet. One thing I dislike about the factory installed Big Foots is they use little feet about 7" not the normal Big Foot 10" feet which have the corners bent up so if you drag them they won't dig in as easily.
ATVer is offline   Reply With Quote
Old 05-18-2013, 12:31 PM   #3
Plain Old Member
Same as ATVer. Never a problem on the road, yet. Misses my shop ramp by 3/4" or so while backing in. Don't like the minimal clearance, but it is what it is. They're all that low. Air your bags up as much as your comfortable with (60-70 psi seems to be the average on here) and gain that extra bit of clearance if you haven't already.
John and Rebecca Dickson
Emma-7 / Little John-5 / Iva-1
Full Timing Again, Rev B
2013 Ford F-350 Lariat CC LB PSD
2015 SOB TT - With OC's Awning Poles (#8)
At least in Heaven, RVs will be perfect, and I won't have to keep fixing them.
BigJohnD is offline   Reply With Quote
