Old 11-25-2016, 10:27 AM   #1
KnC
Bigfoot control panel and other items
Second time out with brand new Sunseeker 2860DSF. Really like it but unfortunately, have had a few bugs to work out in addition to just learning the ins and outs of various systems.
One thing I've noticed is the Bigfoot leveling system control panel powers on by itself (lights come on and sometimes off) fairly often. Do others have this happen as well? I have had to disconnect and reconnect the connector on back of the control panel for other reasons so I believe the connection is secure.
Also, different issue. The GFCI has tripped a couple times in the bathroom. Can't think of anything that would have overloaded the circuit. Any thoughts or lessons learned.
________________________
2017 Sunseeker 2860 DSF
2016 Harley-Davidson FLHTK
Nights camped: 2016-6, 2017-32, 2018 - 21 2019-21
KnC is offline   Reply With Quote
Old 11-25-2016, 11:29 AM   #2
World Wide Wanderer
wahoonc's Avatar
Check the other ends of the Bigfoot cable. Normally mine will cycle when I turn the ignition off, but that is the only time I have noticed it.
With the GFCI don't forget it controls several other plugs down stream from it. On my Concord they have stickers on them. Could be a weak ground on one of the plugs or a loose connection causing it to trip.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 11-27-2016, 03:40 PM   #3
sgtlm17's Avatar
First thing to check is batteries. Low batteries will cause condition you describe on bigfoot.
2016 Forester GTS 2801QSF
2011 Jeep JK Toad
Habitual RV Modifier
sgtlm17 is offline   Reply With Quote
Old 12-04-2016, 07:23 PM   #4
I also have a 2017 2860 DS with the same Bigfoot issue. Where is the power connection found for this? Where's the other end of the Bigfoot cable located?
Thanks,
Marc
2018 Newmar CanyonStar 3710
Mgosselin is offline   Reply With Quote
Old 12-04-2016, 07:26 PM   #5
sgtlm17's Avatar
Your bigfoot is run off your batteries. The cables go directly to your batteries and typically bypass your battery cutoff switch. Once batteries are fully charged you can reset control panel by disconnecting the plug in rear of control panel for 30 seconds.
2011 Jeep JK Toad
Old 12-04-2016, 09:36 PM   #6
Thanks, I'll give that a try the next chance I get.
Old 02-03-2017, 11:02 PM   #7
Did you figure the Bigfoot issue out? Ours does the same thing but only seems to be when the furnace kicks in.
pcryer is offline   Reply With Quote
Old 02-03-2017, 11:17 PM   #8
Mine come on when the furnace comes on.
AbdRahim is offline   Reply With Quote
Old 02-04-2017, 05:12 AM   #9
No, i havent figured it out yet, my Sunseeker is resting for the winter. I'll review this issue with my dealer in the spring, only 8-10 weeks to go!
Marc
Old 02-04-2017, 07:28 AM   #10
KnC
at dealer
Mine is at the dealer now. I'll post what I find out when I know.
Old 02-17-2017, 09:53 PM   #11
Have you found out anything yet? Our's is being looked at now. The tech said that the Big Foot panel is coming on when the furnace igniter comes on. He hopes to have it figured out my mid-week.
Old 02-18-2017, 09:00 AM   #12
KnC
Thanks for the info. We haven't picked it up yet. Supposed to do so the beginning of next week. However, I don't think the issue's been fixed because they couldn't replicate it (having it come on). The furnace connection will definitely be something I'll check out.
Old 02-19-2017, 09:56 AM   #13
Chief tinkerer
Gidyupgo's Avatar
So, I have noticed ours lights up on it's own when first powering it up getting ready for a trip, etc., but no pump or anything. Just lights and displaying "out of level" condition. I have also noticed that at some point it goes back to sleep. I guess I always figured it was normal, doing a self check or something, making sure the legs were where they were supposed to be in case there was a bypass and one of them had crept down on its own.
Gary
2017 SunSeeker 3010DS
Gidyupgo is offline   Reply With Quote
Old 02-19-2017, 10:35 AM   #14
Gidyupgo that is normal. Not normal to light up when the furnace kicks in.
Old 02-19-2017, 02:45 PM   #15
Bigfoot not working
I have a 2016 Sunseeker and my levelers stopped working. They did come on when I cycled the ignition and gave me a low power error. I checked the batteries and found no problem. Even reset the controller. What I did eventually find when inspecting the batteries was that the main power cable for the leveling system was not connected to the breaker/fuse mounted in the battery box. The connection from batter to breaker/fuse was OK, but the output had only an empty wire lug. Found the wire in the battery box and re-crimped the terminal lug. Problem Solved.
rvharrison is offline   Reply With Quote
Old 02-22-2017, 08:54 AM   #16
KnC
Follow-up
I picked up the RV last night. They didn't do anything to fix the issue since it wasn't on for them. I should've lit the furnace to check but didn't. So, at this point, I don't know if it's still an issue or not. With the weather being nice, hopefully we'll take it out in the next couple weeks and see how things work.
Old 02-22-2017, 05:31 PM   #17
Just talked to the dealer. Between them and Forest River, they have decided to replace the furnace control panel and see if that fixes the issue. Something about the frequency coming off the the panel. Hopefully we will know more next week.
Old 03-20-2017, 11:46 PM   #18
Furnace panel has finally arrived and dropped off the RV at the dealer. I will be real surprised if that fixes the issue. Big Foot suggested moving the sensor. Only time will tell.
Old 04-15-2017, 09:44 PM   #19
Well, I guess I will add this to my dealer's work order for the annual visit. Someone must have an answer.
Old 04-15-2017, 09:55 PM   #20
Still trying to get ours fixed. They received the wrong part so we are waiting for the part. In the meantime we got hit with tennis ball size hail =(
