Originally Posted by ATVer
I have a 2012 3120 with the factory installed big foot jacks. It is a 4 pump system so there are pumps at each corner. The front pumps are bolted up using holes in the frame just ahead of the cylinder bracket. The rears are bolted to the same bracket as the jack cylinders. Not sure if Ford or FR specifies the locations but in the front I think they should have been installed about 3-4 inches further forward so 13 inch stroke cylinders could be used. The 11 inchers severely limit the effectiveness of the system.
I have the locations for the jacks.. it's the single pump that needs to be mounted some ware in the middle of the coach to supply all jacks.. but you may have answered a question, if they only use the auto system this bracket would not be used and would not be installed..
