Old 09-12-2016, 12:49 PM   #1
Black Tank Flush Question
Let's say for arguements sake when flushing your BT you don't follow instructions and leave the tank closed to get a good rinse. Being absent minded you walk away for a bit and then notice a bit of water coming from the storage bin opposite of the sewer bay. You immediately drain the BT, clean up a small amount of water in the bin and can't find any other water anywhere in or under the rig. So, where did that water come from?
Linda
LTRVing is offline   Reply With Quote
Old 09-12-2016, 01:36 PM   #2
nomad297's Avatar
I would guess that it leaked out of the top of the black tank at the gasket where either the toilet drain or vent stack enter. It then traveled along the top of the tank and ended up where you found it.
Bruce
nomad297 is offline   Reply With Quote
Old 09-12-2016, 03:38 PM   #3
Rich.M's Avatar
x2 , probably just a gasket since it's a gravity drain. It would have come out the roof vent with better seals.
2015 Solera 24r
2017 Jeep Wrangler
Rich.M is offline   Reply With Quote
Old 09-12-2016, 04:32 PM   #4
Thank goodnes it was minimal. Small timer now attached to control panel to time and buzz flushing time. Thanks.
Linda
Old 09-13-2016, 12:58 PM   #5
I set the timer on my phone since its always in my pocket when moving around doing other things during the flush.
pkeene is offline   Reply With Quote
Old 09-13-2016, 01:11 PM   #6
When I flush my black tank I never walk away. I'm just too forgetful to take that chance. So I just stand there drinking my beer and listening to the tank fill.
hatchet
HATCHET19 is offline   Reply With Quote
Old 09-13-2016, 02:13 PM   #7
Black Tank Problem
Had to respond to "Hatchet19"... at my age if I stand there drinking beer listening to water run in the tank... well then I have to be using that tank real soon!
Bstoermer53 is offline   Reply With Quote
Old 09-13-2016, 02:16 PM   #8
So, lesson learned?...X2 for previous responses.
Never, ever, walk away from this task.
slipf18 is offline   Reply With Quote
Old 09-13-2016, 02:20 PM   #9
BamaBob's Avatar
You should be OK - did that when we owned a 5er....so now I am paranoid. I just run the black tank rinse with the valve open...for @ 45 min
Bob & Anne-Marie [BamaBob & 6 Actual]
| 2017 Berkshire XLT 43A with Ultrasteer Tag | Blue Ox Avail + KarGard II |
| SMI AF-1 Air Brake | 2016 Jeep Cherokee Overland TOAD | Pedego Bikes |
Nights Camped: 2013 - 242014 - 422015 - 56Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 09-13-2016, 04:29 PM   #10
Put a shot of dawn detergent in both the grey and black tanks on the way home and add a little bit of water. this sloshing around helps to clean them and it seems to work well..
Brandon2
2014 2500TS
Sun Seeker
brandon 2 is offline   Reply With Quote
Old 09-13-2016, 04:33 PM   #11
I was told that if you were to do what you did that the water would come up through your toilet and flood your bathroom floor in your camper.
flagstaffman is offline   Reply With Quote
Old 09-13-2016, 04:53 PM   #12
Was the water that spilled out black water or fresh water?
dalford is online now   Reply With Quote
Old 09-13-2016, 05:32 PM   #13
Fresh water, 2nd rinse. No smell at all, lucky, bleach cleaned all we could see. I normally babysit the process, however, just as I started I got an important phone call and got distracted for a few minutes too long. As soon a you think you've got this RV thing figured out, wammo, live and learn. Fortunatly no small animals were harmed during this screw up. ;-)
Linda
Old 09-13-2016, 05:40 PM   #14
BandJCarm's Avatar
Rule 1: There are no important phone calls.
Rule 2: Blank Tank work requires direct oversight. It's like a 3 year old boy. Never turn your back.
Rule 3: Water is our blessing, and our enemy. Corralling it is one tough task!!
Rule 4: Gravity always wins in a battle including water.
Rule 5: Never mix hoses.
Rule 6: ....... Not sure there is a rule 6..........
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 09-13-2016, 05:58 PM   #15
mikkeeh's Avatar
Good thing this is a theoretical problem and didnt really happen!
mikkeeh is offline   Reply With Quote
Old 09-13-2016, 06:33 PM   #16
DouglasReid's Avatar
When Im flushong the black water tank I NEVER walk away from the camper. My wife monitors the level gauges and when it gets to 3/4 I drain it, probably do this twice each time we are leaving the campground.
There are too many horror stories of tanks bursting, falling, etc. to get in that big of a hurry!
DouglasReid is offline   Reply With Quote
Old 09-13-2016, 06:58 PM   #17
Citrus County, Fl.
GL1800Rider's Avatar
I am always right at the connection or the faucet when I flush. Last time we were out the Pex connection where the hose hooks up broke on the barb after about a minute. Fortunately we had roughly a half gallon of fresh water to clean up. And for those who are wondering, I had my regulator and gauge on it and it was set at 40 psi.
2016 Forester 3011DS
2017 Toyota Corolla SE toad
PREVIOUS: 2015 Flagstaff 832IKBS
99 Terry 31G
GL1800Rider is offline   Reply With Quote
Old 09-13-2016, 07:12 PM   #18
45 Minutes?
BamaBob;
Do you run it 45 minutes after EVERY BT flush or only when you are done camping and going to store it. That's a lot of water........I am fairly clear after a few minutes.......
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 09-13-2016, 07:14 PM   #19
Farkasb's Avatar
If your hose was hooked up to the black flush hookup there's a chance a hose or plastic fitting cracked. Happened to me, had a lot of water leaking down. Since it was fresh water it confused me till I found the problem.
2016 Forester 2401WS
Farkasb is offline   Reply With Quote
Old 09-13-2016, 08:10 PM   #20
Bilcin's Avatar
Absolutely correct. I had this happen. I was back flushing the black tank and got side tracked. Well, several minutes later I am outside the trailer and water is coming out of the slide seal. I rush around the trailer, shut the water off and go inside the trailer and water all over the bathroom floor and leaked into the living room slide and leaked out. I opened up the toilet lid expecting to see a toilet bowl full of yucky water. No water. The water was forced up and out of the seal between the toilet and the flange, and that broke the seal and had to be replaced. Bleach, bleach and more bleach for the floor. I now have a timer with alarm so I don't do this again.
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
black, black tank, black tank flush, tank
