Old 02-24-2017, 11:05 AM   #1
Black wash has no flow; blocked nozzles?
My 2015 Sunseeker black tank flush no longer works. When water hose is connected no water flows. Need to know how to access the flush system to repair. Remove outside fitting and hose just disappears. Worked correctly last fall using my home water hose.
Is it true you can use up to 80psi air to unclog?
13larry is offline   Reply With Quote
Old 02-24-2017, 11:25 AM   #2
Have you checked the anti-siphon, anti-backflow valve?
They can stick shut.
It is often located under the vanity in the bathroom.
Looks like this...
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 02-24-2017, 11:29 AM   #3
What model is your Sunseeker RV? Mine is a 3050s
Old 02-24-2017, 06:21 PM   #4
Forester Fred's Avatar
Read this post, I fixed mine. I also replaced the plastic anti siphon valve with a brass one. I'd be careful about using 80psi....I don't know how strong the connections are.
http://www.forestriverforums.com/for...ut-106550.html
2015 Forester 2301 - Chevy
Skip & Deb
Forester Fred is offline   Reply With Quote
Old 02-25-2017, 01:13 PM   #5
Telstar's Avatar
The spray head on our tank was clogged. I replaced it with the new rotating type, works much better.
Gary and Donna
2005 Cardinal 33TS-LX
Trail Air pin box
Center Point suspension
2018 Ram Laramie 3500 6'4" box 2WD
Demco AutoSlide 18k
Telstar is offline   Reply With Quote
Old 02-25-2017, 01:37 PM   #6
Hey_nav's Avatar
Just got mine back from dealer here in Florida for the same thing. They claim "it was just clogged with debris from the black tank". Since nothing was "broken", it was not covered under warranty and cost me $149 to fix. I used it religiously for two months and then all of a sudden it stopped working. With an anti-siphon valve on the system, i'm not sure how debris got into the nozzle and clogged it up... but thats what they're claiming.
Gabe
2016 Dynamax Force 37BH HD
2016 Jeep Wrangler Unlimited - Rubicon Hard Rock
Hey_nav is offline   Reply With Quote
Old 02-25-2017, 01:56 PM   #7
Sagecoachdriver's Avatar
What would happen if you filled the black water tank with hot water and added a few tank tablets letting it sit for a few days. Then drain and try flushing? Do you think it would soften the clog and allow it to clear?
On my Forester 2701ds, the black tank flush is visible in my outside compartment where the water pump and filter are located. Mine appears to have just 2 screws holding in with silicone caulk. I could also unclamp it and blow out the nozzle if needed.
2004 Winnebago Minnie 22e(went to a nice family Oct 3, 2015)
2016 Forester 2701DS (Aug 31, 2015)
2017 Camping 12 trips 38 nights
2018 Camping 10 trips 38 nights
2019 Camping 6 trips 19 nights
2020 Camping 0 trips Cancellations 6
Sagecoachdriver is offline   Reply With Quote
Old 02-27-2017, 02:25 PM   #8
Black wash has no flow.
Have experienced similar problem with my 2016 Georgetown 378XL. Do to other problems didn't get to try black wash til enroute to Florida. 1st time out found it would not allow flush water to flow into tank. Notified dealer, and started flushing with a wand. Thanks to post on forum which provided a picture of the valve. I located mine in closet plumbed for washer. Removed valve and checked, no obstruction. Further analysis led me to conclude valve was installed backwards (inlet to outlet and oulet to inlet). Removed it and reinstalled other way. Water now flows into flush system. My concern now is that the reconfiguration changes the horizontal/vertical layout of the valve. (Pic of new config attached). Any one know if the will present any problems.
(Note, picture taken with IPad, but system turns upside down when posted.)
RVnMarine
GT 378XL
RVnMarine is offline   Reply With Quote
Old 02-27-2017, 06:05 PM   #9
Black Tank Flush
I had the same problem. I solved it by first determining that there was no blockage between the inlet and the valve. Then I checked the valve to make sure it was working properly. Then, I squirted about 1/2 cup of Calgon liquid into the line going to the tank. Let it sit for a couple of days. Hooked everything back up, connected the flush hose and turned it on. Worked like new!
mikej248 is offline   Reply With Quote
Old 02-27-2017, 06:28 PM   #10
Last year, I mixed SuperClean/Pinesol/water in equal parts and had no problem in the Blue Streak. Over the summer the mixture evidently congealed and wouldn't flow, so this year I just used a 50/50 mixture of SuperClean and water and it worked great. Waste just dissolves and doesn't solidify. We DO NOT put any paper products in the black tank tho. We tow with about 2-3 gallons of water flushed down the toilet which is the above mentioned mixture from the Blue Streak. I've also removed the backflow vent and hose completely from under the bathroom sink and the black tank inlet goes directly to the tank nozzle. The inlet has a factory installed backflow preventer right behind the inlet.
Old 03-02-2017, 11:05 AM   #11
anti-siphon, anti-backflow valve location Sunseeker 3050s
Does anyone know where the anti-siphon, anti-backflow valve is located in a Sunseeker 3050s?
Old 03-02-2017, 03:35 PM   #12
Hoglou's Avatar
Try an experiment with ittle calgon in a cup of tank (like tst) treatment. Report back and let us know if that is what you want in your tank... Made a goo type paste when I sampled it. Using the geo method may be great but mixing the two is problematic from my view..
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 03-05-2017, 06:36 PM   #13
I would like to know also??
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 03-13-2017, 08:01 PM   #14
appalachian trail's Avatar
Mine was located behind the drawer in the bathroom vanity. The factory black plastic valve was sticking so I replaced it with a brass retrofit one that I found on E-Bay, no more problems.
appalachian trail is offline   Reply With Quote
Old 05-05-2017, 06:22 PM   #15
Black Tank washer doesn't work
I have a 2011 Sunseeker 2300 with the same problem. The backflow valve is located high up behind the vanity sink and I have no idea how to get to it. Is this valve necessary? If I ever can get to it, I just want to get rid of the thing! How can black tank liquid ever back up to the washer inlet which is just below the outside shower?
davegood is offline   Reply With Quote
Old 05-05-2017, 07:53 PM   #16
If you have a back flow valve at the city water inlet connection for the black tank you can just cut the hose and connect it to the hose going to the black tank flush and leave the valve under the vanity there.
Name:	Black tank back flow valve 1.JPG
ID:	136885   Click image for larger version
Name:	Black tank back flow valve close up.JPG
Old 05-06-2017, 10:16 AM   #17
Total Loss's Avatar
The cheap plastic backflow valves are...well...cheap.
My aftermarket one I installed only lasted a year.
"If you are going through hell..keep going"
W. Churchill
Total Loss is offline   Reply With Quote
Old 05-06-2017, 10:19 AM   #18
I think what you are saying is to cut the hoses on either side of the backflow valve and connect them together. So the valve is really not necessary. My problem is the valve is way up under the sink and I don't think I can get to it without removing the sink or possibly the outside shower.
Old 05-06-2017, 10:45 AM   #19
Cut them wherever you can get to them.
Often times the lines go up through (and then back down) the basement or a compartment. You can often eliminate several feet of plumbing.
Old 05-06-2017, 11:02 AM   #20
bubbles's Avatar
This is not the same company made valve as the black ones but they function identically and are the same inside. The input to the tank from the valve is through a normally closed spring loaded ball shut off valve that prevents any backflow. The disk shut off valve on the input side rises to allow flow to the tank valve. The disk valve cavity is vented to allow the disk to collapse back to the input side port. Water that's still in the input side tubing will drain back out but is in no way contaminated. When flushed there is no water in the holding tank and it is also vented. No one has ever explained how this system can contaminate another system. There is only one side of this valve that ever has positive pressure and it is the input side. Due to the construction there is no syphoning possible (dual shutoffs).This is for those so adamant about using a dedicated hose for the cleanout. Personally, because of the routing of the cleanout tubing (several feet above the tank) I think it's overkill.
Name:	vacuum-breaker clear.jpg
black, lock
