Old 10-22-2016, 10:10 AM   #1
Brake and directionals problem
I have a 2014 sunseeker based on a chevy 4500 has anybody had a problem with no brake or directional on the drivers side need help.
sunseeker5 is offline   Reply With Quote
Old 10-22-2016, 10:14 AM   #2
You've probably already done it, but easiest thing to check is the fuses. Usually each side is fused separately, so if you're having issues with just one side, it's a good chance it's the fuses.
Sometimes when a brake/turn signal light blows out, the falling filament shorts out the bulb and blows a fuse.
2011 Traverse LT, 3.6L, FWD
Old 10-22-2016, 11:05 AM   #3
Iwannacamp's Avatar
If you haven't...check the bulbs. If the hazard switch is on the column...flick it off and on several times. Seen many signal problems fixed by that....usually older cars....unless you armoarall a lot or someone spilled something in there. Cheap check.
2017 Puma 297RLSS
