Old 02-28-2012, 05:06 PM   #1
zook's Avatar
Brake Plug?
I'm looking for the factory plug under the dash of the E-450 2012 3120 DS?
This is the pigtail that the brake controller hooks into.
Anyone know for sure where this plug is?
zook is offline   Reply With Quote
Old 02-28-2012, 06:46 PM   #2
TURBS's Avatar
I can not tell you but normally its taped back to another harness and sometimes you don't notice it right away . and normally its a grey connector .
I dont know if i helped or not
Old 02-28-2012, 08:02 PM   #3
The 2012 E450 has a trailer brake controller as an option.The controller would be located just above and to the left of the radio in the same area as a coin holder.If your motor home is not equipped with a factory brake controller,then the wiring connector should be behind the coin holder.You may have to get an adapter plug to hook in an after market controller.
09grizzy1
09grizzly1 is offline   Reply With Quote
Old 02-28-2012, 08:18 PM   #4
Wanderluster
OffPavement's Avatar
If you find it, please take a picture and let me know! I've looked everywhere under the dash and behind the radio with no luck. I want to use the brake control lead as a brake signal indicator for the Invisibrake in my toad.
The Road To Paradise Is NOT Paved!
Brian & Margie
www.rv-camping.org
OffPavement is offline   Reply With Quote
Old 02-28-2012, 11:23 PM   #5
MotocrossCamper's Avatar
This was on etrailer.com, Not sure if thats what your 2012 dash looks like. I have heard that they are on the passenger side of the radio. I was also told by the shop that is working on my hitch that even some of the new Fords still put it right by the e-brake pedal so it may be worth taking a look there.
MotocrossCamper is offline   Reply With Quote
Old 02-29-2012, 09:05 AM   #6
Coachmen Adrenaline
As grizzly mentioned, I believe it is the connector on the backside of the coin holder on the dash. I will get ahold of my ford service guy to verify this. pictures attached to help you locate.
ID:	10631   Click image for larger version
ID:	10632   Click image for larger version
ID:	10633   Click image for larger version
ID:	10634   Click image for larger version
jamiller45 is offline   Reply With Quote
Old 02-29-2012, 09:06 AM   #7
Coachmen Adrenaline
couple more pics of the plug.
ID:	10636   Click image for larger version
Old 02-29-2012, 09:15 AM   #8
zook's Avatar
Thanks for the replies so far, but it looks like this plug can be anywhere.... I will now make if my mission this weekend to find this plug even if I have to tear the entire thing apart.. but I will find it and take a picture to be posted on Monday.. But if anyone knows for sure where to send me searching I will take the leads..
Old 02-29-2012, 09:16 AM   #9
zook's Avatar
Now that's what i'm talking about..
Old 02-29-2012, 09:27 AM   #10
Coachmen Adrenaline
zook, those pictures I posted are of a cab chassis on the line right where yours was built...I am certain that yours will have the exact same plug behind the dash. Like i said though, i am waiting for the service tech to call me back to verify that it is indeed the brake controller plug.
Old 02-29-2012, 09:51 AM   #11
zook's Avatar
Jamiller I was informed by Unified Tow Brake to use the AP Products adapter EC-4129 Pigtail marked Winnebago, that one has a small 3/4" square plug.. but I had also gotten a Pigtail from PPL that looks close to matching the plug you show in the picture.. so still not 100% what one I need.
But thank you very much in advance for the help so far..looks like I'm not the only one in need of this info..
Old 02-29-2012, 08:55 PM   #12
Wanderluster
Along with the pix... Thanks! Now all I gotta do is figure how to remove the dash bezel to get to it. Did you notice... is it actually attached to a dash bezel somehow?
Brian & Margie
www.rv-camping.org
Old 03-01-2012, 08:31 AM   #13
zook's Avatar
Ok this morning I got to the plug, it is as simple as pulling on the dash trim around the Radio, don't be scared just grasp it and pull.. this plug is directly behind the coin holder... more to follow..
ID:	10667   Click image for larger version
Old 03-01-2012, 09:43 AM   #14
zook's Avatar
This is the picture of the wiring harness I got from PPL for the Ford, as you can see it is a plug and play for the Prodigy brake controller,, my problem is the Controller for the Unified has different pig tails and the one I have does not match up.
ID:	10673   Click image for larger version
ID:	10674   Click image for larger version
Old 03-01-2012, 10:06 AM   #15
zook's Avatar
So my question is if I splice the plugs together what one is what? on the controller side I'm being told Black is ground, Red is Keyed power, Orange is brake lights, and Blue is line,
so on the Coach side is
Blue line?
Red?
Black?
White?
Old 03-01-2012, 10:54 AM   #16
Coachmen Adrenaline
ok here we go... on the top row of the plug starting with the yellow red and working towards the blue...
y/r - constant hot
purple - brake signal
black - ground
white/orange stripe - ignition switched on
I dont know what the blue wire does, it wasn't giving me anything. but the 4 above should be all you need. if you need help matching up how to splice them together or anything else just let me know.
Old 03-01-2012, 10:55 AM   #17
Coachmen Adrenaline
also the 2 small white wires on the bottom row have a constant 2.5Vdc. not sure what those are for either.
Old 03-01-2012, 11:21 AM   #18
zook's Avatar
I will have to look at what color from my plug goes into the plug on the coach. But all i have to work with is
Red
blue
white
Black..
Old 03-01-2012, 11:36 AM   #19
Coachmen Adrenaline
I'm certain you will do it correctly. feel free to ask if you have more questions.
brakes
