Old 02-28-2018, 10:47 PM   #1
Bunk bed area conversion
We are working on becoming full timers and I have a question about bunkhouse coaches. Is it possible to remove the beds completely and put a small recliner in that area with a TV and create a "man cave" type area. I watch a lot of sports and my wife doesn't so having two tv areas would be nice. Has anyone tried this?
2008 Georgetown 373DS
kenlea98 is offline   Reply With Quote
Old 02-28-2018, 11:05 PM   #2
clarkbre's Avatar
Anything is possible. In most of the double over double bunks, the upper could be removed to make a big cavity. You couldn't stand in it but could certainly make a space for a recliner.
It also wouldn't be crazy as a reading or work area for a couple trying to maximize space in a trailer.
2017 Forest River Surveyor 247BHDS...
...Tugged by a 2016 F250 XLT FX4 SuperCrew, Shortbed 6.2L, 4wd, 3.73...
...Joined with a Husky Centerline TS 800-1200lbs WDH
clarkbre is offline   Reply With Quote
Old 02-28-2018, 11:53 PM   #3
Always Learning
Should be possible, but I'd measure the depth. My camper is a fifth wheel but the bunks are only 30" deep and the bunk slide is only about 32-36" deep. Can you fight a recliner in that area?
Old 02-28-2018, 11:58 PM   #4
Kaadk's Avatar
Considering this is in the Forester section, I think the OP was referring to a set of kids bunks in a Motorhome. I don’t have much familiarity with Motorhomes other than walking through a few demo units, but based on that limited knowledge, I’m going to hazard a guess he’s referring to one of those bunk in a closet type spaces. If so, yeah, I guess it could be done, as long as you had a narrow enough recliner to fit in there, and if there’s nothing under the bottom bunk allowing you to go down to the floor. Not knowing your layout at all (tried googling the model number in your information and not getting a concrete hit) I can’t really say more than idle speculation.
Old 03-01-2018, 03:10 PM   #5
We have a Coachman Freelander 31BH. It has bunks i removed the top bunk. It has a dinette for 2 people table 2 seats a tv & radio across the hall. I use this as my man cave & office.
Jim
jimmiejim is offline   Reply With Quote
Old 03-01-2018, 03:32 PM   #6
We have a heritage glen 42’ 5ver with a bunk house. It came with a double bed below and a single above. I converted the single to a double bed for now. We have put a large TV in the bunkhouse. My kids are 15 and 18, once I they stop wanting to go with us, I plan to replace the lower bed with a sofa, and keep the upper for guests. The bunk house would be a home office, extra TV / sport viewing room
Jeff from Burlington Ont is offline   Reply With Quote
Old 03-01-2018, 07:19 PM   #7
Hank
Coachmen Leprechaun upgrade
This is what I did to my Bunk house model. I removed both bunk beds and built a support frame for a sofa bed. A leaf can be raised and the bed extended to maybe support 2 small children. I did not bolt the unit down and it can be easily removed so I can use the area for something else. A small TV is in the area that can play movies and you can connect a game controlled to it
Hank
ID:	163851   Click image for larger version
ID:	163852   Click image for larger version
Henry Barnes is offline   Reply With Quote
bed, bunk
