Old 07-20-2019, 10:57 PM   #1
Cable not working
When plugged into cable I recieved no stations. I've heard of turning off antennae booster but I cant find it. 2014 sunseeker any ideas it is not on the tv power plug.
Rcceo is offline   Reply With Quote
Old 07-21-2019, 08:45 AM   #2
A32Deuce's Avatar
Booster switch should be in the location of where cable comes from the wall into the tv.
A32Deuce is offline   Reply With Quote
Old 07-21-2019, 08:47 AM   #3
Like 32Deuce said. Little button on the plate with cable connection and a little green light next to it.
TheWolfPaq82 is offline   Reply With Quote
Old 07-21-2019, 10:10 AM   #4
2012 Solera
As stated above.
On our 2012 Solera, the 12 volt “cigarette lighter“ outlet the TV plugs into for power is incorporated in the same plate. The antenna boost switch and its little green light are “hidden” behind the 12 volt power outlet and TV power plug.
JLeising
2012 Solera "S"
Calif SF Bay Area
JLeising is online now   Reply With Quote
Old 07-23-2019, 03:51 PM   #5
If it's like mine, the cable input would have never worked despite all the button pushing and fancy green lights.... Has yours worked, in the past?
Here's what I found:
Assembly... Give a monkey a zip router, and he'll route anything in the way...
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 07-25-2019, 09:11 PM   #6
Antenna booster
When hooked to cable the picture is very fuzzy I was told to turn off antenna booster. It is not near antenna cable or near exterior cable connection. Any other ideas where this switch is?30 ft sunseeker 2014
Old 07-25-2019, 09:14 PM   #7
Mr. Dan's Avatar
Can you tell us the model number of this rig? It's length doesn't help people know its internal configuration.
SEARCH is your friend!
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 = 64; booked = 30
Old 07-25-2019, 09:45 PM   #8
dcheatwood's Avatar
On my Forester, similar to sunseeker, the booster is in the small cabinet above the entry door. It has a 12 volt outlet and a cable connection and a small button that turns booster on and off. Button In/ light on = booster on, for antenna/air signal.
Button Out/ light off = booster off and ready for cable. After locating booster, turn it off, go to television menu and set tv input to Cable. Run channel scan.
Done.
2018 Forester 3011 DS
Old 07-25-2019, 10:04 PM   #9
Thanks I dont have that. Where the cable comes out it doesn't have a button or anything any other locations?
Old 07-26-2019, 09:03 AM   #10
look on the wall behind all the tv's you have.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 07-26-2019, 11:29 AM   #11
dcheatwood's Avatar
Or places where there are tv hookups even if no tv is there.
Old 07-26-2019, 11:33 AM   #12
dcheatwood's Avatar
Looking for something like this. Black arrow is tiny button. Green arrow is small led light. May or may not have a 12 volt outlet. Click image for larger version
Old 07-26-2019, 12:09 PM   #13
Thanks I will keep looking
cable, sunseeker
