Old 01-23-2015, 10:14 AM   #1
mary ferguson's Avatar
Cable power booster
Morning! We are at. KOA that has cable TV and we don't know where to turn the power booster off in our 2014 class C Sunseeker? HELP! I'm watching only 2 channels!
mary ferguson is offline   Reply With Quote
Old 01-23-2015, 10:29 AM   #2
Phat Phrog Stunt Crew
elind's Avatar
Look at the cable wall plate to see if there is a little red light, a little button. Push the button and the light should go off. Next, train your TV programmer to find all the channels. Go to menu, set it to cable, scan channels, about 2-3 minutes and that should do it. Also when your on the antenna you need to scan this at every location.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 01-23-2015, 11:54 AM   #3
We did all that has we've none of its working
Old 01-23-2015, 12:22 PM   #4
Boso's Avatar
The booster on mine was on the cable plate up on the over head bunk couldn't see it until I crawled up on the bunk small button where wire are for tv
i2015 sunseeker 3050s. 2007 saturn aura
Boso is offline   Reply With Quote
Old 01-23-2015, 12:24 PM   #5
Boso's Avatar
Also a button on antenna that might effect it on near the ceiling
Old 01-23-2015, 01:10 PM   #6
Motorized GM
Do you have a switch box? If so, it may be built into that.
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 01-23-2015, 01:18 PM   #7
bikendan's Avatar
i thought RV's had an antenna booster switch, but not a CABLE booster switch?
why would you need to boost the cable signal?
Equalizer WDH
Old 01-23-2015, 01:18 PM   #8
If you have the TV in the cabover area, there are two boosters, one is deep on the right hand side of the TV the other is a the base of the antenna, you can barely see it as the button is hidden by the cable wire.
Learned that off a friends 3050 when they could not get good cable at the park on our vacation trip to FL together.
jbrostek is offline   Reply With Quote
Old 01-23-2015, 01:31 PM   #9
Scootdawg's Avatar
In my 2014 2900 the cabinet up top directly behind the drivers seat, inside is where the tv plugs in, I had a little button that when pushed would turn the green light off so that I could watch cable.
2014 F-150 SuperCrew
2015 Rockwood 8289WS Diamond
Scootdawg is offline   Reply With Quote
Old 01-23-2015, 01:36 PM   #10
That would be the one, but in the 3050 its above the passanger seat and barely visable.
Old 01-23-2015, 01:42 PM   #11
Scootdawg's Avatar
Great news!
Old 01-23-2015, 01:50 PM   #12
Boso's Avatar
I also have a 3050 mine is a 2015 model the booster was above the drivers side but not viewable unless you were up on the bunk or had a ladder and there is a switch on antenna took me awhile to find the one above the drivers seat in bunk area
power
