Old 09-10-2020, 12:15 PM   #1
cabover floor structure
Hi, does anybody have any knowledge of what is under the deck on my sunseeker 2650 DS cab over? fixed a roof leak and may have some moisture underneath. Would like to add a few soffet vents to help dry out and to see if there is any standing water under there without removing the floor.
grandpajoe is offline   Reply With Quote
Old 09-10-2020, 01:23 PM   #2
Ambassador Member
Duckogram's Avatar
All Wet
Why not use a Damp Rid big bucket?
Ducky
‘18 Sunseeker 2800QS
Towing Smart
No PM’s.
Old 09-11-2020, 10:25 AM   #3
water under cabover platform
Ducky, I think the damprid would work once I open up a hole to see what going on under the deck. right now it is coming up from a very small seam where the plywood comes together. Would like to drill a 3 inch hole to explore then install a round sofet vet to vent.
Old 09-11-2020, 10:28 AM   #4
Commercial Member
under the cab outside is fiberglass and Azdel, with aluminum frame and block insulation, 1/2 plywood and decorative décor board on the interior. Everything is laminated together to form one solid structure.
I hope this helps.
Kary Katzenberger
Product Manager
Forest River Class C Division
karykatz is offline   Reply With Quote
Old 09-11-2020, 12:26 PM   #5
Thumbs up water under cabover platform
Kary, Thanks for the information. Should there be some room between the aluminum frame to drill a 3 inch hole. Do these supports run from front to back? Would you know the center to center spacing? We have had this unit 10 years and basically trouble free, very happy with it.
Thanks for your help much appreciated
Old 09-11-2020, 12:36 PM   #6
Commercial Member
if you send me a PM with the last 6 of your vin and model number I will see if I can dig up a drawing and send. I'm traveling most of next week so it may take a few days.
Kary Katzenberger
Product Manager
Old 09-12-2020, 08:28 AM   #7
Kary, I found a yellow sticker on the left door jamb with these numbers:
Vin #4X4MSSC24BF020332
1FDXE4FS7BDA05624
My model is 2650DS I believe. 28ft long one slide.
I believe Jeff in Technical support was trying to find this also. One other thing I may need is the part number for the screen door latch? Our local dealer was trying to get this fore me and I never heard back from them. it has a cutout on one side so a generic assembly wont fit. Again thanks for all your help.
Joe Rossi
Waterbury CT
Old 09-23-2020, 10:40 AM   #8
Kary, was the information I sent you last week adequate?
Joe
Old 09-24-2020, 01:55 PM   #9
Commercial Member
joe
will you PM me with your email. I have engineering drawings and tried posting three times but I couldn't get it to let me download.
Kary Katzenberger
Product Manager
Old 09-26-2020, 08:52 AM   #10
Kary did you get my email address?
floor
