Old 04-19-2015, 10:39 AM   #1
Cabover tv
Hi I have a 3120ds with a cabover tv.Can anyone post a pic of how the tv is installed?The tv was stolen from mine and when I picked it up the dealer gave me some a new tv but didn't have the brackets.I moved to another province and he sent me new brackets but I can't seem to get the tv mounted.The motor home has the entertainment option.Any help would be greatly appreciated.
Thank you.
malagusta is offline   Reply With Quote
Old 04-20-2015, 07:34 AM   #2
Class C Representative
Joshua Cavitt's Avatar
It is in on drivers side of the cab over. Similar to where a 3050S TV is located. You have to make sure to hit the backer when putting the brackets in wall.
Joshua Cavitt is offline   Reply With Quote
Old 04-20-2015, 08:50 AM   #3
The original poster said he had the entertainment option so I believe the TV would be mounted in the middle of the cab over.
ATVer is offline   Reply With Quote
Old 04-20-2015, 09:04 AM   #4
Missed that second to last sentence. My apologies lol
Old 04-20-2015, 10:50 AM   #5
Commercial Member
Post a picture of your current set up (without the TV). That design has changed over the years.
If "Search this Forum" does not yield answers, please post questions as a "New Thread" (Do Not Ask in a PM) so others can benefit from the answers.
Sales-Service-Parts https://dynamaxcorp.com/contact-us
Old 04-20-2015, 12:09 PM   #6
This is from our head engineer........
"I believe there may be a wood trim piece below the TV that screws on. After removing this, there should be a black metal bracket visible. It should have 2 screws below the TV and 2 above it. TV and bracket should now be loose. Just reverse this to install it."
Old 04-20-2015, 12:23 PM   #7
the first image is a view of the space with an angle on top and one on the bottom.The second is of the 3 brackets the dealer sent.The 2 angles are the same as the ones already installed and the other rectangular one is the other bracket.The tv he gave me is a 32 inch tv.
Thank you
ID:	74804   Click image for larger version
Old 04-20-2015, 05:01 PM   #8
the 2 angles seen in bottom pic are the same as the 2 in the top photo.One on bottom and one on top
Old 04-20-2015, 07:52 PM   #9
Hard to tell but it looks like the flat plate like bracket will bolt to the back of the TV. I see what appears to be 4 holes in it that would mount to the back of the TV.
There also appears to be 2 holes in each of the top and bottom bar like brackets that would line up with holes along the edges of the plate like bracket. It kind of makes sense that someone stealing the TV would just remove the 4 bolts from the horizontal bar brackets then take the TV along with the plate like bracket. My 3120 does not have the entertainment option so I can't send a photo to help.
Old 04-21-2015, 09:38 AM   #10
I thought about that also but the holes on the plate don t match with the tv holes.I guess I will have to find a dealer here and see if they have any idea.It has confounded my friends here too,and one guy is good at puzzles.Thanks for the input.When I get it figured I will post results.Again thank you for the help.
Old 04-21-2015, 10:01 AM   #11
Commercial Member
What you have on the table should make an "H". The top and bottom horizontal bars stay there.
Installed those two angles vertically one on each side and then the square bracket mounts to those. TV mounts to the square bracket. If the holes don't line up, we probably drilled them as needed.
Old 04-21-2015, 04:35 PM   #12
Possibly the replacement TV has different hole spacing. Unless it is exactly the same make and model TV it may be different. If the bracket will work otherwise and position the tv correctly in the cabinet just go ahead and redrill the holes to make it fit.
Old 04-21-2015, 06:26 PM   #13
Dealer gave me wrong tv.Got TV from in house holes matched perfectly put in space but square bracket is 3 inches too short.Small holes on horizontal angles match small holes on small holes on rectangular bracket.The 2 angles he sent are the ones that are already installed in space.The 2 angles he sent threw me.Now just have to get longer rectangle.Thank you again for help.
