02-18-2016, 01:41 AM
Circuit breakers
Help!!! I've read the book and went to generator in the rain, in the dark. I cannot find them. I've located the fuses but they look okay. The gfci is fine. I have power to all but two outlets.
02-18-2016, 02:07 AM
If you have power to all but two, your generator is putting out, and supplying all but those two.
You might have two branch circuits; even if they look like they are on, try turning off all breakers and back on again. A tripped breaker doesn't pop to the off position, but only a bit off center.
Also, you might also have two GFCIs.
Let us know what you find.
2016 Sunseeker 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
02-18-2016, 02:10 AM
I can't find any circuit breakers to throw �� I've located house fuses which is the location the book gave for circuit breakers. I have one gfci that I'm aware of and another that is tied to that. That's hasn't helped
02-18-2016, 09:02 AM
What are you in make & model
2015 sunseeker 3050s. 2007 saturn aura
02-18-2016, 10:56 AM
2015 Forester 2401R MBS
Fonzie
02-18-2016, 11:07 AM
Under the bed??
02-18-2016, 11:37 AM
It's a forester 2401R MBS
02-18-2016, 01:03 PM
Both the fuses and breakers are located in the converter panel under the edge of the bed:
Open the panel by pushing on the cover as the latch is a push to open, push to close style.
I don't have an image of the contents - but there's generally 6 breakers in addition to the 12 volt fuses. There's also fuses in the panel to the left of the first step in the stepwell in our 2250; I suspect yours is similar. The fuses are for 12 volt items, so these won't help in your case.
On our old motorhome, some 110V outlets were connected to the microwave circuit. The circuit with the GFCI controlled the remainder.
2012 Solera
On our 2012 Solera "S", they are in a black plastic box under the stove. "Power distribution box" I think. Thumb nail slots to pop open the cover. Circuit breakers (for 110 volt circuits) on one side; automotive type fuses (for the 12 volt circuits) on the other side.
Look for a plastic panel somewhere (likely near the floor and likely somewhat near the middle of the coach).
JLeising
2012 Solera "S"
Calif SF Bay Area
02-18-2016, 01:23 PM
Thank you both very much!! I found it this morning. It is under the stove near the floor. I feel pretty stupid right now
02-18-2016, 02:41 PM
Was one of the breakers needing reset?
02-18-2016, 09:51 PM
There sure was! Thank you for asking
02-18-2016, 10:30 PM
Thanks for reporting back. We like to read of solutions and you have 2. Now you know where your breakers are AND you reset one to solve the original problem.
02-19-2016, 08:56 AM
Good to read your up and running!
1930 lbs CCC
2014 Jeep Rubicon JK
