Ok, I did get the tap and once we got far enough South to de-winterize, I very carefully started the tap by hand, only a turn or two once I was confident I wasn't cross treading it. Backed it out, cleaned off the rust with some WD-40, back in by hand adding an extra 1/2 turn. Once I got about 3 turns on the die, it started to go very easily, still cleaning and adding a 1/2 turn at a time. I believe, knowing how far my anode rod used to install 3 or 4 threads was probably all it was inserted. I needed to use a wrench to keep turning, but only because I couldn't still turn it with my fingers. Probably cleaned up 5 threads or so.
I cleaned the threads as best as I could and the added Teflon tape to the anode rod, it screwed in easily and straight, much better then any previous installation. Perfect, no leaks.
I agree that caution is warranted doing this, but I think that my threads were rusty and a bit buggered up, this really cleaned up the threads and made inserting the anode rod a snap. Will look into some grease to help minimize rusting in the future.
Linda
