As you've probably seen in
one of my other threads, I'm moving the entertainment center/TV from the center of the overhead to the right wall in the overhead.
I have a question for the collective knowledge of the group: Two runs of RF coax were routed to the back end of the antenna amplifer (white panel with power tap & F connector on the visible front side). These two were:
Black - run from the park F connector in the rear storage bay (and cut nearly in half 6" away from the amp probably by the router while cutting the holes in the panel, Arg!)
Gray - RF coax to the King Jack box for the antenna.
Here's the back of the antenna amp/power tap:
I see a third in the overhead of this cabinet just to the left of the radio:
This cable is bright purple; it is routed from a hole at the juncture of the wall & ceiling in the access hole at the top of the cabinet. It is connected to a plate with an F connector in the ceiling of the small storage behind the door to the left of the radio.
What is this purple RF coax used for? I don't currently have a pic posted on line but will get one added to this post.
Thanks in advance!
