Old 03-10-2019, 10:00 AM   #1
tvj
Convenience Center hot water
So the convenience center in the Forest River sunseeker has to water heater options gas or electric you can run them both together over ride each other and work properly or just one or the other. I recommend the electric when you're hooked up to electric. One has to look really hard in the instructions to find out how they work. See my post on the bypass valves buried under the sink behind a screwed on panel.Click image for larger version
tvj is offline   Reply With Quote
Old 03-10-2019, 10:04 AM   #2
yes you can run them both at the same time or independently .
MR.M is offline   Reply With Quote
Old 03-10-2019, 10:05 AM   #3
wmtire's Avatar
Originally Posted by tvj View Post
So the convenience center in the Forest River sunseeker has to water heater options gas or electric you can run them both together over ride each other and work properly or just one or the other. I recommend the electric when you're hooked up to electric. One has to look really hard in the instructions to find out how they work. See my post on the bypass valves buried under the sink behind a screwed on panel.Attachment 198436
Looking at that panel, your RV could have either an Atwood brand water heater or a Suburban SWDEL water heater.
If you have the Suburban brand SWDEL water heater, this thread we keep in the FAQ subsection will explain it all:
http://www.forestriverforums.com/for...ore-36197.html
2011 Flagstaff 831 RLBSS
I've reported my DNA missing just in case it's found somewhere bad.
Old 03-13-2019, 03:18 PM   #4
OK, now Iím thoroughly confused. What is the benefit of running them both at the same time?
ksdindy is offline   Reply With Quote
Old 03-13-2019, 03:26 PM   #5
wmtire's Avatar
Faster recovery time. That way if you take a longer shower or have others in line behind you, the water can be heated back quicker using both modes of heating at the same time.
Old 03-13-2019, 03:27 PM   #6
SailorSam20500's Avatar
Water heats up faster with both running.
Al
Save the Earth. Itís the only known planet with Beer.
There are times where my greatest accomplishment is keeping my mouth shut...
S.E. Mich. Flagstaff 26FKWS / 2019 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 03-13-2019, 03:29 PM   #7
I have a Sunseeker 3050 S it has both options as well. Can I literally just flip either switch or both? Iím confused if thereís anything I need to do directly at the water heater
Old 03-13-2019, 03:35 PM   #8
wmtire's Avatar
Read the link above in post #3. It thoroughly explains the operation of...as far as a Suburban brand goes.
hot water, saunseeker, sunseeker, water
