01-28-2016, 11:00 AM
geezer with gadgets
Converter has died
My converter has died. Had the elecrician came and checked and he confirmed the death.
I'm looking at the progressive dynamics converter with the charge wizard for replacement. The old WFCO unit is 55 amp (MH is 30 amp). Do I need to match the amps to the old unit? I can find 45 amp, 60 amp, etc., but not 55 amp.
Thanks in advance for your help.
Sent from my Atari 2600
2011 Sunseeker 3170ds "Ladybug"
2017 Jeep Grand Cherokee TOAD
Days camped 2015: 37; 2016: 66; 2017: 86 2018: 57 2019: 30
01-28-2016, 11:33 AM
You can go up to the 60. No problem.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
01-28-2016, 11:34 AM
Think this may be what you are looking to find.
55 Amp (PD4655V)
Inteli-Power 55 Amp Converter/Charger
Model #PD4655V replaces these converter sections: Parallax/Magnatek #6355, Parallax #7355, Parallax #7155,
Parallax #8355, WFCO™ #8955
2013 Flagstaff 831FKBSS
01-28-2016, 11:44 AM
Converter has died
I have one for sale.
Drop in replacement.
New in the box never opened.
http://www.bestconverter.com/8955MBA...l#.VqpFLkVOLCQ
Randy at best converter recommend this over a progressive dynamics.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
01-28-2016, 11:49 AM
Can ship today!
2015 Columbus 320RS
2008 2500HD Duramax
01-28-2016, 11:52 AM
Originally Posted by TURBS
Best bet right here!!
2016 Sabre 36QBOK
01-28-2016, 01:31 PM
One advantage of the Progressive Dynamics line is that you can connect a pendant and FORCE the converter to go into boost mode. This means that if you boondocking and using a generator, you can maximize the few hours of run time to get as much battery charge as possible. The PowerMax does not appear to offer any manual control of charge level. If you aren't boondocking it really doesn't matter.
2015 335DS
01-28-2016, 01:52 PM
Boondocker also has a a boost mode 14.6v
KEY FEATURES:
14.6 Boost Mode Output
13.6 Normal Mode Output
13.2 Float (trickle) Mode Output
Built-in desulfation cycle
Over-temp, Over-current Protection
Temperature tested to 160 F
105-130 VAC Input Operation
Reversed Polarity Voltage Protection
>85% Efficiency
Safe, Cool, Quiet & Reliable Operation
<1% Load Regulation
Constant Current Charging Technology
Filtered DC Output (Works with or without a battery)
Thermostatically Controlled, Variable Speed Quiet Cooling Fan
3 Year Hassle Free Limited Warranty
2015 Columbus 320RS
2008 2500HD Duramax
01-28-2016, 05:09 PM
For sure it does, no converter could work without one. However, you can't force it to go into Boost mode, it makes its own decision and when it drops out you get a very low charge rate. If you are persistently plugged in, that is no problem. However, if you are cranking a generator while boondocking, as soon as it drops out of boost, you get what you get.
2015 335DS
01-28-2016, 05:26 PM
What happens if you forget the boost mode is on, since it is manual, and you run a long charge? Will it cook the batteries? I would think that a charger that monitors the charge level automatically would be better for the batteries in the long run.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
01-28-2016, 06:30 PM
Randy at best converter recommend this unit of progressive dynamics after I asked him which converter is best for boon-docking.
Hands down the "boondocker" it's named that for a reason ✌️
2015 Columbus 320RS
2008 2500HD Duramax
01-28-2016, 06:41 PM
I agree that the Progressive Dynamics with the charge wizard is the way to go. Had one in my last rig and I will be replacing my WFCO in my motorhome with one soon. We mainly boondock. It's takes more than a product with the "boondocker" name to convince me.
2009 Sunseeker 2860DS
Bulldog keyless entry
Firestone airbags
Airlift remote compressor system
Ultragauge EM Plus OBDII monitor
01-28-2016, 06:53 PM
Actually the microprocessor will revert from boost to normal after a period of time automatically to avoid issues. Of course, you can hit boost again to keep going. Strangely my Trimetric shows 14.5 volts applied whenever I am running the engine on the RV, so 14.5 can run for a long time with no serious issues.
2015 335DS
01-28-2016, 07:04 PM
I guess I'd not take the word and advice of a guy who sells converters for a living.......
2015 Columbus 320RS
2008 2500HD Duramax
01-28-2016, 09:36 PM
Since I have one of those, I'm curious how you do that.
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 FR Forester 2401R
Towing 2014 Honda CR-V
01-28-2016, 09:48 PM
You buy the optional $12.00 pendent that connects via a data cable, then you can override the automatic cycles when needed. Google the converter and you will see this accessory.
Firestone airbags
01-29-2016, 01:03 AM
Thanks!
01-29-2016, 01:46 AM
2015 Columbus 320RS
2008 2500HD Duramax
why are you selling it? what converter do you have installed?
01-29-2016, 04:09 AM
You are correct but it will drop out of boost mode by itself down to 13.6 then if you want you can put it back into it, but it will drop down by itself when it reads the voltage.
As far as the person who asked about getting the pendant, if you get the WFCO 8955 / replacement the new board has a button that you push and you do not need to buy a pendant. Progressive makes a 55 amp direct replacement.
To the OP Your best bet would be just buy turbs, It is a very good power center also, and is also a direct replacement...
Coachmen M/H
Concord
2018 / 300 DSC
01-29-2016, 07:18 AM
I bought it to to put in my unit that was supposed to have a Wfco "junk" as it turned out it was a progressive dynamics.
2015 Columbus 320RS
2008 2500HD Duramax
