Old 07-16-2018, 08:14 PM   #1
Crack in Shower Stall
Hi everyone!
I have a crack that started right at the connection that holds the shower head on in the plastic. We covered it with packing tape and its been that way for a while with no problems and it has not propagated.
Does anyone know what type of plastic we have on the side walls of the shower?
Any suggestions on how to repair this crack?
Also my plastic seal on the bottom of the door has torn. Any suggestions on what to replace it with?
Thanks!
Mike
MikeRP is offline   Reply With Quote
Old 07-16-2018, 08:17 PM   #2
asquared's Avatar
On my Sabre the shower is fiberglass. When ours cracked, it was under warranty and they had a fiberglass specialist repair it. I would be leary of the packing tape as it is not likely preventing any water damage from occuring.
<a href=https://i62.tinypic.com/28rp645.jpg target=_blank>https://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 07-17-2018, 08:47 AM   #3
I also have a crack and will attempt a fix soon.
I plan to try Bondic and see if this plastic weld kit will work. I will post results later...
A short term fix might be the clear Gorilla tape.
sask is offline   Reply With Quote
Old 07-17-2018, 02:24 PM   #4
So here is my attempt with Bondic . I actually had 2 cracks originating from same point at the edge. I cleaned the area with alcohol and pushed the crack in and out to get the adhesive onto the edge of the plastic. I used the UV light and cured it. I then applied a couple of more layers on top of the crack. It hardens with a bit of an off white colour which is noticeable. I will leave it and see if the adhesive weld holds. If yes then maybe some touch up paint to hide the weld.
Old 07-17-2018, 03:53 PM   #5
That looks almost exactly like mine but in a different location thanks!
Old 07-18-2018, 01:09 PM   #6
Attachment 180040
Attachment 180041
Attachment 180042
Drilling the holes to stop the crack run is a good idea. I would have probably used some kitchin/ bath caulk in white. My thought us the color would blend better and the caulk is somewhat flexible. Good luck.
Luke Moseley is offline   Reply With Quote
Old 07-18-2018, 01:27 PM   #7
amblt's Avatar
I've had good luck with clear silicone aquarium sealant. It seems to adhere well to most surfaces, and is not as visible as you may think. (it is very shiny, however).
It's held a few badges to a pewter mug for nearly 40 years.
Cheers
amblt is offline   Reply With Quote
Old 07-18-2018, 01:29 PM   #8
Fully COVID-19 vaccinated
How about Eternabond tape?
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
timfromma is offline   Reply With Quote
Old 07-18-2018, 03:52 PM   #9
Hoglou's Avatar
Sask.. looks good thus far. Is the repair material soft or rock hard? Given the viscosity I would razor cut or dremel to match the surface and paint with acrylic (like from hobby lobby). I bet 30 minutes would make blend pretty nice.
Hoglou the DH & BK the DW (retired and happy)
WestGA KM4HQQ 146.640mhz
Check out the "mods" in the albums
Old 07-18-2018, 03:55 PM   #10
Certified Curmudgeon
Duckogram's Avatar
I don’t think bondic will hold up on pvc but worth a try
Welcome to Lake Wobegon where Justin and David utilize abductive reasoning to help solve F/SS issues.
Happy Trails and Remember the Pequod.
Old 07-18-2018, 04:17 PM   #11
Hoglou's Avatar
pvc?
Didn't know that. Opens a few interesting potentail ways to fix. Love to have a sample piece of the material and play with some clear Oatley with a micro applicator. Any chem eng's out their to chime in?
Ya rusty top, its been with me awhile..
Old 07-18-2018, 07:38 PM   #12
Shower wall repair
It you have ever worked with fiber glass repairs (such as boats or surfboards) they are fairly easy to complete even as a novice! The materials can be found separately or in repair kits at auto part shops, boat supply shops, some RV sales and parts shops, and even wall mart! Just follow the directions! Use the cloth and rest of the kit as the directions state! Most people screw up by using too much of the “liquid hardener” and too soon! After it dries you can lightly sand it! I add the color to the mixture and it usually matches up on white pretty well! If you screw it up not too badly you can usually salvage the work by patiently using light sand paper then laying down a single layer of fiber glass again! Then after it’s dry sand smooth and mix up a bit of top color and paint it again! If done right it will outlast the rest of the fiberglass in the shower! It will also look nice! You can practice on any old piece of fiber glass first! Just take more patience with grooved areas! I first learned growing up in California and repairing my surfboard! I just as too poor to pay to have it done! Later woke on active duty and my wife and I were visiting family I would repair my father’s boat dings and cracks! It’s like most repairs! Learn a bit! Practice a bit! Just do it! Save yourself a ton of money! Keep a small kit in your RV on the road in case of emergency repairs inside or outside! Dan
Dan n Gerda is offline   Reply With Quote
Old 07-18-2018, 07:54 PM   #13
This stuff is UV hardened plastic and it seems pretty hard. I tried to lightly sand it and the sand paper did not really touch it. I did not want to get too agressive and start sanding the actual shower. I will try a razer knife next or maybe a dremnel. I did want some overlap of material to strengthen the repair seam. If I had of realized how hard it would set, I might have been a bit more careful with the layers.
According to web site the plastic can be colored ahead of time but must use acrylic micro powder.
https://notaglue.com/blogs/what-is-bondic
Old 07-19-2018, 07:43 AM   #14
Wolverine 1945's Avatar
Originally Posted by MikeRP View Post
Hi everyone!
Thanks!
Mike
If you can find out your dealer who makes the shower door,,, you can order a new bottom seal !!!
Wolverine 1945 is offline   Reply With Quote
Old 07-19-2018, 12:14 PM   #15
Another option for you
3M Marine Adhesive/Sealant 5200: Amazon.com: Industrial ...
https://www.amazon.com/3M-Marine-Adh.../dp/B01D893FTW
3M Marine Adhesive Sealant 5200 3M Marine Adhesive Sealant 5200 is a one-component, high-strength, moisture-curing, gap-filling polyurethane for permanent bonding of wood, gelcoat and fiberglass. It cures to form a firm, rubbery, waterproof seal on joints and boat hardware, above and below the waterline. This product has been trusted throughout the marine industry for over 50 years
2015 Rockwood 8289WS
2003 Dodge Cummins w/Banks 3:73
CraigBean7672 is offline   Reply With Quote
Old 07-20-2018, 08:43 AM   #16
I do not know how old this unit is,,, but I guess I would try to replace the panel !!!
Old 07-20-2018, 10:13 AM   #17
Duckogram's Avatar
I believe the OP’s unit is a 2012 3010DS.
Old 07-20-2018, 10:23 AM   #18
A unit that new I would try to replace the panel,,,
It could become a problem if he ever wanted to sell it ???
crack, show, shower
