Old 01-17-2019, 03:52 PM   #1
texasblues's Avatar
Dash Mounted Jensen Radio/GPS System
I have a 2015 Sunseeker 2800 QS and I am wondering if there is a way to turn off the cab door speakers when using the four ceiling mounted coach speakers when watching the tv or listening to music. Right now the cab door speakers and the four ceiling speakers all work together. Hope someone can help. Thanks
texasblues is offline   Reply With Quote
Old 01-18-2019, 02:11 PM   #2
Interesting. Ours has the (worthless) Jensen in the dash, but it drives only the cab speakers. The entertainment center above the side entry door runs the house speakers, and has 3 outputs. We have two internal and two external speakers. The default when the center is initially powered up is to run all outputs, inside and out.
(Soapbox) I say the dash unit is worthless, as the GPS appears to have been designed by someone on a huge desktop monitor. When the map is reduced to the small display, it's almost completely unreadable. I like to use my dashtop Garmin anyway - it's much easier to use, and is consistent no matter what vehicle I put it in!
Additionally, the thing died a while back - no power whatsoever. We rarely used it anyway, so I haven't spent much time trying to troubleshoot it. All fuses are good, so it's an issue with the supply wiring or the unit itself. As the entire dash facade needs to be removed to access it on our GM, I probably won't bother until I find a decent replacement.(/Soapbox)
2016 2250LE/Chevy
Formerly: 2000 Four Winds 26Q/Ford, '96 Kit Sportsmaster 22' 5th wheel, '91 Sunlite truck camper, Wildernest flip-top canopy
brucemc is offline   Reply With Quote
Old 01-18-2019, 02:32 PM   #3
texasblues's Avatar
Yours is different from mine. I fo not have a coach system like you described. Everything is controlled by the dash Jensen. I do not have outside speakers, only four ceiling speakers one coach bass, and cab door speakers. I have used the gps a lot and mine works ok. The only issue I have is if I try to adjust the gps volume, it also adjust the music volume. Can not adjust them separately. I hate that.
Old 01-19-2019, 09:16 AM   #4
JoeSteiner's Avatar
There is a 'fader' adjustment you can make in with the equalizer settings. If I'm driving, I adjust the speaker output all the way to the front. When watching a movie, I adjust the fader to the rear.
JoeSteiner is offline   Reply With Quote
Old 01-19-2019, 09:40 AM   #5
texasblues's Avatar
Ok thanks Joe. I will give that a try.
Old 01-19-2019, 05:33 PM   #6
Darth
Originally Posted by JoeSteiner View Post
There is a 'fader' adjustment...
It's name is Darth.
Larry
Larry-NC is online now   Reply With Quote
Old 01-21-2019, 01:45 PM   #7
not sure if yours is the same as our 3051 Forester. The one thing I don't like is that the outside speakers are controlled by the inside radio not the out side one.
RETIRED U.S. NAVY
2017 FORESTER 3051S
IN SO-CAL
Philkaty is offline   Reply With Quote
jensen, mount, radio
