Old 01-30-2015, 06:00 PM   #1
Dining Table
My Table is 32" tall. This makes setting at table writing letters gets uncomfortable after a while. Most tables are 29". Has anyone tried lowering their table? I called the 800 number on the table and they said they build it 29", but Forest River installs above the wire run down the side of the wall/floor, making it higher than designed.
J. V.
2015 Sunseeker 3050s
15 Years Full Timing
Now own Sticks and Bricks
J. V. is offline   Reply With Quote
Old 02-01-2015, 01:10 AM   #2
Motorized GM
They were supposed to make us a table that was 2" shorter to accommodate the wiring run. Maybe that never happened. If you look underneath, I wonder if you could drop the table 3" and just add another stop for the lever?
Please READ the entire thread before posting to keep comments relevant.
Also, please post questions as a "New Thread" (not private message) so that others can benefit from the answers. Use Private Messages for sensitive information only. Owners manuals are available online and via iPhone/Android Apps.https://www.dynamaxcorp.com/OnlineManual.aspx
Old 02-03-2015, 12:01 PM   #3
Thumbs up Table Too High
O. K. thanks. I moved the lock rod out to the edge of the table and was able to cut a new notch in the track so it the table is now 29".
