04-23-2019, 02:15 PM
#21
The ice chest is for the water, gator aid , and BEER. Especially when the grand kids join in on the trips. Out side for quick access! AND No electronics allowed!
Cheers David
04-23-2019, 02:22 PM
#22
As mentioned, this has been discussed here many times. Briefly, some experts say there's a fire risk when in a gas station where someone near the fridge access is refueling with gasoline. I used to run with the tanks/fridge on, but started turning them off when I realized the fridge and freezer lose only about 1 degree an hour if it starts off cold and is turned off for travel. So for the last few years we turn it on the day before departure and turn it off when we hit the road. Frozen stuff stays frozen even after 6+ hours on the road in hot weather.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 30 Months on the Road Since 2008
04-23-2019, 02:25 PM
#23
Depends on how hot the weather is . Doesn't work too well for long travel days in 100+ temps.....
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
04-23-2019, 02:36 PM
#24
Yes and refrigerator on.
04-23-2019, 02:56 PM
#25
I see that raised as an issue at times, but I'm having a hard time seeing it being an issue. I can't see any scenario where you'd have someone within 8' or so of the fridge vent refueling. And I don't see how you'd ever have a high enough concentration of gas fumes at that distance and height from the ground to ever come close to igniting. I see a real genius every now and then actually smoking while refueling- now THAT makes me nervous!
04-23-2019, 03:00 PM
#26
Originally Posted by Mach428
Disregard those negative comments about doing searchs. The answer is yes, I leave my propane on all the time. Good advice about tunnels and when filling propane tanks
There is nothing negative about suggesting someone do a search of the forum.
Especially on a topic that gets contested weekly.
04-23-2019, 03:29 PM
#27
Always. Except when they made us shut it off on the ferry from Nova Scotia to Portland last year.
Campah
2017 Rockwood 2109s Mini Lite
04-23-2019, 03:36 PM
#28
ARLO
all the time except border crossing and tunnels.
04-23-2019, 03:37 PM
#29
ARLO
Ditto. How did you like Nova Scotia? We thought it was great.
04-23-2019, 03:46 PM
#30
In what order do you turn off your propane when you are gassing up at the station propane first then fridge, or fridge first time propane?
2017 Cherokee 294bh
2014 Ford F-150 3.5 ecoboost
04-23-2019, 03:51 PM
#31
You can just turn off the fridge. The keeps the flame from coming on.
04-23-2019, 05:19 PM
#32
Denver To Yuma In 90 Days
Just turn off the gas at the tank.
Don't need to switch it off inside.
And it will fire back up when you turn the gas back on again without having to go inside, although I do go in before I hit the road just to make sure the light is orange (meaning fridge is running on LP).
04-23-2019, 05:22 PM
#33
Check the manual for your fridge, if it loses gas and tries X number of times to relight without success it may register a fault and need to be reset by turning it off/on for it to try and relight again.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
04-23-2019, 05:28 PM
#34
I've never had that happen in many many years of RVing.
Mine always have fired right back up!
04-23-2019, 05:42 PM
#35
I travel with mine on as well so the fridge will get/stay cold for when we reach our destination. Have never had an issue but you never know what possibly could happen.
#36
Yep...which is the reason you turn off the fridge. Mine will immediately fault once it tries to light it. Unfortunately, it only tries once and then sets the fault. Mine is a Dometic.
04-23-2019, 05:57 PM
#37
And ferries.
04-23-2019, 06:26 PM
#38
All the time. I run on electric several hours before loading the fridge and insure it switched to lp before departure.
04-23-2019, 06:42 PM
#39
Just turn it on and leave it on.
LP needs to be turned off when refueling the tow vehicle...diesel or gasoline.
Why? Gasoline fumes would have to be deep enough to knock you out for there to be any danger from a burning LP flame. Unless you refrigerator is right next to the fuel filler.
I've never seen a tunnel posted to turn off LP appliances other than the Chesapeake Bridge-Tunnel here in Virginia. The tunnels under the Hudson River may be restricted as well, but that's it. None of the tunnels in Pennsylvania are restricted. Anyway the few restrictions are prominently posted. LP restrictions for semi trailers don't apply to recreational vehicles -- and they're prominently marked as well.
-- Chuck
04-23-2019, 06:52 PM
#40
I would be curious about how long the fridge would run after shutting at the tank. I may test it.
2017 Puma 297RLSS
