Dometic Refrig Issue
When hooked up to shore power for several weeks. Noticed every time opened refrig door could smell propane. Never smelt it in coach otherwise. Did notice it outside around tank. Had lines checked when temp tank attachment was done. No leaks were found. I do know the pad site was not level. I did try to use support jacks & boards to bring it more level. Heater was used most the time. The smell was always inside the refrig every time it was opened.
The recall was preformed on this unit. However a elec wire did come loose causing it to not work. That was. Fixed and it worked fine just smell of propane when gas button was pushed off.
