Old 11-24-2020, 01:34 PM   #1
Tombsy's Avatar
Door Strut
On my 2801QS when my door is open it is only a couple of inches away from the extended living room slide.
I have put some pool noodle on the corner to protect it because the door opens so quickly if you are not holding it , it will slam into the slide.
I’ve changed the strut but it only helps to prevent the wind from slamming the door shut.
Any ideas of what I can do to prevent the door from opening so violently? Is there such a thing as two-way struts?
Brian
2015 Forester 2801QS GTS
TOAD-Hobie Mirage Pro Angler 14 kayak and Yamaha Zuma 50cc scooter on a custom trailer.
Tombsy is offline   Reply With Quote
Old 11-24-2020, 02:14 PM   #2
Would it help if your strut was ever so slightly shorter? On our Sunseeker 2440DS, the gas spring strut was poorly located to where the door would hit the awning arm if the awning was deployed. It only needed to keep the door an inch or so away from the awning and it would be fine. After trying to find a slightly, like 1/2” shorter strut to no avail, I figured out how to shorten the strut with a little careful sawing of the struts end fittings. The fittings are threaded on. I unscrewed the ends and cut off maybe 1/4” on the female part, but it still left enough thread engagement for a strong attachment. It’s hard to explain without a picture, but anyway my slightly shorter strut solved my door/awning interference problem.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
BehindBars is offline   Reply With Quote
Old 11-24-2020, 04:26 PM   #3
Ambassador Member
Duckogram's Avatar
Brian mine does not hit the slide.
Just Ducky
Towing Smart
No PM’s (they are not private anyway)
Posting exclusively in the Forester/Sunseeker section for the amusement of fellow Forester/Sunseeker owners.
Old 11-24-2020, 04:41 PM   #4
Kanadian Kamper
kenandterry's Avatar
I entertained all the ideas listed so far by my most intellectual friends.
I finally attached some paracord, and used wire eyelets on the ends. I drilled pilot holes in the top of the door and on the underside of the drip rail at the top of the door. Then I attached the eyelets with self tapping screws.
A few trials of what length of paracord, and it stops the door from hitting whatever.
Easy peasy.
Ken and Terry
2018 Sunseeker 2430S
and might rarely get pushed by our 2017 GMC Terrain toad (4 wheels down)
Former Georgetown 330TS owner for 10 years with more mods than I can count.
kenandterry is online now   Reply With Quote
Old 11-24-2020, 05:15 PM   #5
Tombsy's Avatar
Thanks for the ideas, I think the shorter strut would help I have a spare I can play with, but still would like to slow the opening of the door if possible. I guess maybe a less powerful strut and keep an eye out for wind.
Brian
door
