Old 01-27-2019, 12:49 PM   #1
Drain waste compartment
Just bought a 2016 2650S. The compartment for draining the grey and black water looks like there are missing parts.
There is a loose metal bracket attached to the black water pipe, a metal control rod and a vent pipe hanging down.
Could it have been a heater?
willsr61 is offline   Reply With Quote
Old 01-27-2019, 01:59 PM   #2
A32Deuce's Avatar
A picture of what you are talking about would help.
A32Deuce is offline   Reply With Quote
Old 01-27-2019, 06:38 PM   #3
Based on a picture (attached for reference) I found of the sewer compartment of a 2650 here is my best guess.
The bracket comes from the center area to support the black tank drain on the right. The two halves are typically held together with a nut and bolt, the hardware may have come off. I would bet the metal control rod you mention is the other half of the bracket.
The strap and bracket are thin black straps about 1” wide.
If the “vent” you speak of is a 3” diameter foil looking tube just hanging there, it is a duct from the furnace to keep the tank compartment from freezing.
2021 Newmar Baystar 3401
2019 Jeep Cherokee Trailhawk toad
2017.5 Forester 3051S Traded 7/2020
Steve-W is offline   Reply With Quote
drain
